I'm getting to the point of painting my old truck and I am trying to find a color code to use. I want a soft pea green color from an OEM application so I can hopefully get matching paint down the road if needed. Any ideas ?
Sometimes you can find exactly what you need by looking at fleet color chips. Dupont has Spectramaster chips that are available in solid colors and metallics. Every Dupont jobber should have one of each. I'm sure other manufacturers have something similar, but I'm only familiar with Dupont. Stu
Here: http://www.jalopyjournal.com/forum/showthread.php?t=381998 There's a discussion of green going on over there... R-
What I have done in the past ( before I got hung up on making all my pre WWII vehicle projects Black with Red wheels ) is go to a new car dealership or used car lot and find a color I LIKE. I then got the paint code off the vehicle. I have found that a lot of paint color chips are not as accurate as I would hope them to be. Add in that you look at them inside ... not in natural daylight ... and sometimes the color or the chip does not end up looking like what is actually on a finished vehicle.
I have found one that I like by looking here and the TCP library. I want to think about it a week or so before I order the paint. I didn't bother looking at car lots because I haven't seen a color close to what I want in awhile. Seems everything nowadays is full of metallic. I want a straight color without any metallic. I'm really leaning toward 57 Chevy Surf Blue right now.
