http://www.kodakgallery.com/ShareLa...email-_-site_share-_-core-_-view_photos_album Holley V4 Double pumper Double inlet No choke horn from factory (please ignore the spacers and chrome bowls) just need to know what model the main unit is so i can order a rebuild kit for it. the #'s are........ main unit side------t-3 main unit side------p-32 top of main unit---np-1156 base plate---------12r-4507-br base plate----------111503 butterflys------------180 Anyone know what this is? CFM? Model? What it may have come off of? Thanks for your help. Randy
OK, here you go.. By the look of it, the main body was machined off.(the factory hp units have a much larger radius and the casting around bowl vents are more rounded ) No matter though, the butterflies # 180= same as 750 cfm (list # 4779 ) ..#180 also fits other cfm units BUT.. the kit is the same for all the common double pumpers. Holley # 37-489 Do not use any other brand kit,,,you will regret it ! Good luck Dave
