Help Body fillers?
Discussion in 'The Hokey Ass Message Board' started by Swiss50chevy, Jan 13, 2013.
  1. Swiss50chevy
    Swiss50chevy
    What do you guys use for body fillers? Something better then bondo but more use friendly then leading. Ready to do some body work on my belair.
  2. rage extreme or rage gold
    expensive and really expensive
  3. Napa gold just as good as rage but cheaper, nice to work with
  4. Swiss50chevy
    Swiss50chevy
    Anyone heard of filler that sets kinda like metal? Can be used on rusted panels. Coworker was telling me about it.
  5. Stude-sled
    Stude-sled
    Its called All Metal made by USC. Use rage.
  6. Swiss50chevy
    Swiss50chevy
  7. is there any scientific proof that all metal is better than regular filler? or is it just a psychological thing because it looks like metal?
  8. Swiss50chevy
    Swiss50chevy
    There is a thread about all metal filler on here, full of information.
  9. slddnmatt
    slddnmatt
    Rage gold, sucks payin for it though....
  10. slimcat7m3
    slimcat7m3
    try the new stuff from 3m. cheaper than rage and sands great
  11. 3M Platinum Plus Filler is what your looking for
  12. matthew mcglothin
    matthew mcglothin
    Yep x2 on the platinum plus. We use it at work. Very good stuff.cheaper than rage.
  13. 40FordGuy
    40FordGuy
    "Quick-Metal" !
    4TTRUK
  14. Bryan G
    Bryan G
    from Delmarva
    Last time I bought some Rage to try the guys couldn't stand it, insisted I go back to good ole' Super Everflex. Okay by me, a lot cheaper.
  15. jw johnston
    jw johnston
    For rusted panels you need to weld in metal patch panels if you want it to set like metal. Fillers and all metal aint going to cut it......
  16. Noland
    Noland
    yep thats how you deal with rust or atleast rusted threw. you should sandblast all the rusty spots. cant do good bodywork over rust.
  17. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Rage Gold. . . not sure what everyone's talking about it being so expensive. It's $50 bucks for a gallon, are guys really using more than a gallon of filler on their cars?
    I build hot rods, so I guess there's less surface area. But I don't come anywhere close to using a gallon of filler on one car.
  18. norms30a
    norms30a
    I think bondo works just fine. It's going to be a pile of dust on the floor anyway.
  19. RoadsterRod1930
    RoadsterRod1930
  20. 50flathead
    50flathead
    from Iowa, USA
    Rage Gold and yep it's really pretty cheap when you consider everything else there is to purchase. Rage vs lower cost brings a difference of 20-40 dollars on the entire build cost.
  21. lawman
    lawman
    That is some good info fellow's !!!!
  22. before you express your unrequited love for a favorite brand-Find out who makes your favorite filler and you will see that it is likely not who you thouight it was.
    There are only a few actual MANUFACTURERS of body filler in the USA....
    3Mhas now saw fit to purchase and market Bondo filler,Evercoat and USC and others are also quality products as most modern filler is.....
    A short-stranded fiberglass filler is great as a lasting repair,altho it is mean to finish and does at least require a skim of body filler over it to achieve good results....
    Even tho a no filler repair is great if you can afford the work required-It is very reasonable to expect a repair made with modern filler to last many years.
    It is simply a misconception that body filler is not conducive to a long lasting repair in this day and age.......
  23. sorry, i just remember paying $9 a gallon...and it actually WAS a gallon.
  24. FANTASY FACTORY
    FANTASY FACTORY
    all-metal, also available in aluminum, PPG i recall
  25. roddinron
    roddinron
    I've always thought it was used to try to fool the magnets.
    Considering the corrosion problems when aluminum and steel are used together, I wonder if there'd be a problem with the aluminum stuff on a steel body?
  26. Tough to fool the magnets when it isn't magnetic.
  27. pimpin paint
    pimpin paint
    from so cal
    D'oh !
    I used some of the "Bondo" brand of filler awhyle back on a buddy's kids furin POS...........this product wasn't the runny, goopy ,pin hole prone chit from days gone by, and I suspected it was a repackaged product from another source;) Is it as good as the $50 a throw stuff the puttyflingers are willing to die on the cross over..........nope! Will it answer for a low to medium budget build........yep!
    " Meanwhyle, back onboard The Tainted Pork "
  28. mikhett
    mikhett
    from jackson nj
  29. 3M owns them now so it is probably one of their formulations.
