Projects Help! 21 Stud 1935 Ford Flathead
Discussion in 'The Hokey Ass Message Board' started by Nicholas Coe, Oct 21, 2019.
  1. I can't seem to figure out what the part that goes here is officially called. What size bolts do I need?
    Flathead fans, What other parts should I add to this mock up engine for display. Any cool ideas?
    Please post examples of your display engines!
    Nick IMG_20191020_080400.jpeg IMG_20191020_080409.jpeg IMG_20191020_080415.jpeg
    Sent from my Pixel 3a XL using The H.A.M.B. mobile app
    dudley32 likes this.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    You need a 35 ford to finish that mockup.
    Now those two big holes at the bottom front of that engine needs two water pumps.
    Sandgroper, Boden and Nicholas Coe like this.
  3. dudley32
    dudley32
    Not water pumps...they are in the heads...but water necks
    Petejoe, Boden and Nicholas Coe like this.
  4. Ok. Good. So what size bolts do I need for the water necks? Thank you!
    Boden likes this.
  5. Boden
    Boden
    Water pumps are in the head I’m pretty sure
  6. Boden
    Boden
    Shouldn’t be hard to find out? You’ve never had to find a-bolt in the coffee can before. Find just one bolt and then go to the hardware store and say I need a few of these.
  7. If it,s only for display and you don,t have the original water necks/engine mount just use an old exhaust flange .
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    Thx Dudley. Yes I forgot the early 21 bolts had pumps in the heads. Sorry.
  9. I have the original water necks. I was wondering if somebody had access to a repair manual to tell me exactly what I need. I'm a young guy...aka...not much stuff in my coffee can to try. Thank you!
  10. mastergun1980
    mastergun1980
    from Alva OK
    Looks like 3/8 fine
    GH
    porknbeaner and Nicholas Coe like this.
  11. Andy
    Andy
    Here is tip that may come in handy. You will never find fine threads bolts stock in anything cast. The bolts are 3/8 NC stock.
  12. Thank you! I'll try that. Only question would be how long?
  13. Anybody got one of these to help me? I'm heading to the bolt store today with the previous info.
    Nick
  14. fullhouse296
    fullhouse296
    from Australia
    Block it off with a plate .It aint gonna run so who cares ?
    Nicholas Coe likes this.
  15. Good idea. Only I have the water necks to install.
    Thanks, Nick
  16. RichFox
    RichFox
    My '26 Dodge and '32 Plymouth would seem to prove you wrong. More recent iron seems all coarse.
  17. 42merc
    42merc
    Bolt size would 3/8"- 16, about one inch long would work.
  18. Heres mine,very early Roof manifold and a powerhouse gen with an 25 amp alt inside.
    Hotrodmyk and prez like this.
  19. Very nice! Beautiful heads!
  20. 1946caddy
    1946caddy
    from washington
    As stated before, the lower radiator hoses go there and attaches to a water hose neck as well as the front motor mount. You should be able to put your finger to the back side of the hole and use a piece of wire or pencil to measure the depth of the threaded hole and add this measurement to the flange thickness including the gasket. Use some anti seize on the threads.
  21. Deuce Lover
    Deuce Lover
  22. Hotrodmyk and dudley32 like this.
  23. dudley32
    dudley32
    Looks really nice...
  24. Thanks! It was a fun but very expensive"mock up" assembly.
  25. Grab a tape measure. measure the thickness of the flange on the water neck. Add 1/8" for a gasket and about another 3/4" for good measure its a mockup/display motor so exact grip length is not important.
