Technical Hello I'm new here's my ride
Discussion in 'Traditional Hot Rods' started by Boonedogaz, Apr 21, 2016.
  1. Boonedogaz
    Boonedogaz
    Have a question my father in law has a stock 38 sedan & it's still a 6 volt ! I ordered him some hologine head lights of E bay both head lights have power but one is bright one is super dim switched lights & it's the wiring not the light does any one no what could be causing the driver side to be sending such a week current to one side & not the other ! Is it just do to being a 6 volt system ? Thanks
    mgtstumpy, Paul B, Stogy and 2 others like this.
  2. czuch
    czuch
    from vail az
    I'd say check your grounds.
    Dammmmm thats nice.
    1927graham likes this.
  3. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    Assuming you mean Halogen?
    Are they 6V bulbs?
    barryvanhook likes this.
  4. Dim one has a bad ground...check and repair.
  5. Atwater Mike
    Atwater Mike
    Stunning coupe!
    Agree, bad headlamp ground.
    26 roadster likes this.
  6. What they said. ^^^^^^
  7. Boonedogaz
    Boonedogaz
    Thanks I will check it out
  8. Boonedogaz
    Boonedogaz
    Yah halogen I can't spell thanks
  9. Welcome to the Hamb.
    Nice coupe!
    Yep, I'd bet bad ground.
  10. Raiman1959
    Raiman1959
    Welcome....man, that's a sweet car!;):D
  11. CME1
    CME1
    Great looking car! It sounds like you have a grounding problem. Welcome to the HAMB, great place for lot's of good car info!
  12. bostonhemi
    bostonhemi
    Nice car. welcome
  13. Jalopy Joker
    Jalopy Joker
    Cool ride - you will find that many here are not well grounded
  14. slack
    slack
  15. Welcome to the HAMB....Sweet ride and the above are right as far as check the ground.
  16. 210sedan
    210sedan
    from upnorth,wi
    halogen on 6 volts is lame, you have ground problem. but switch car to 12 volt - ground you will be happy
  17. Great look'in coupe, welcome from MN
  18. Welcome to the HAMB.
    Nice car! What's the story?
  19. The problem is probably in the grounds as others have noted. Start looking there. Six volt systems are affected a lot more if there are poor grounds. Did the car get a good coat of paint before assembly, that may be the cause of your ground problem (headlight buckets insulated from fender). Some people actually run a separate ground wire when they cannot locate/solve the problem but you should be able to find it. Although not part of your current problem be sure the battery cables are designed for 6 volts and not new cables from the local auto parts store designed for 12 volts. The old 6 volt cables are heavier. If the starter cranks the car slowly the cables are probably the problem.
    If it turns out not to be a ground problem here is a schematic that will help you trace the wires: http://www.vanpeltsales.com/FH_web/FH_images/FH_electrical-pics/Flathead_Electrical_wiring1938.jpg
    Actually the car is a coupe, not a sedan (assuming you are talking about the one in the picture in the first post).
    Be sure to also visit fordbarn.com.
    Charlie Stephens
    arkiehotrods and czuch like this.
  20. A quick way to confirm that your problem is with bad grounds is to run a piece of wire from the ground side of the battery and touch it to the grounded part of the headlight socket. If the light gets bright you know where to start looking.
    Charlie Stephens
  21. When you have fixed the grounding issue can you please post up a ton more photos of your gorgeous coupe, oh and welcome also:) JW
  22. Flathead Dave
    Flathead Dave
    from So. Cal.
    Nice coupe.....Need more pics of it.
    Oh, and check the grounding.
  23. keywestjack
    keywestjack
    from Pittsburgh
    Please post more photos.
  24. Can U Tig it?
    Can U Tig it?
    from Central PA
    Let's see under her bonnet!
  25. Boonedogaz
    Boonedogaz
    The coupe is 12 volt it's mine the 6 volt is my father in laws car & yes it was the ground thank you every one ! Should've none it was because of a repaint the head light bucket wasn't getting a good ground ! Here's the car [​IMG] again thanks for all the advice & kind words about my 38 coupe !
    mgtstumpy and LOU WELLS like this.
  26. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    Welcome, Glad the brain trust helped you out. Both yours and your in-law's cars are very nice. More photos would be welcome.
  27. heavydumper
    heavydumper
    Two nice looking cars you have there. The green color on the sedan is really nice. Would like to see more photos of both cars. 6 volts is plenty if you set them up right. No need to switch to 12v providing all is correct.
  28. redo32
    redo32
    I was wondering about the wattage of the 6volt halogen bulbs and if they should have a relay?
    26 T Ford RPU likes this.
  29. WOW What a sweet ride!
    Welcome!
  30. mike bowling
    mike bowling
    Welcome to the Jungle!
    Nice cars-
