Technical HEI Distributors
Discussion in 'Traditional Customs' started by 64impala, Aug 29, 2016.
  1. 64impala
    64impala
    1964 Chevorolet Impala SS
    327ci (Rebuilt) 25K Miles
    350 Auto Tran
    AfterMarket Upgrade(s):
    Edelbrock exhaust manifold, 300 cfm 4bbl carb, electric fan, digital dash, 95amp alternator.
    I need to upgrade my antiquated Mallory Unilite Electronic Ignition (15 years old) and
    signs of failure!
    What are a few recommended HEI distributor(s) that would fit my application.
    This is a cruiser/custom, no burning rubber!
  2. squirrel
    Countn'Carbs likes this.
  3. Keep your antiquated Mallory for nostalgia and put a PerTronix Ignitor inside it :)
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    My antiquated unilite is 23 years ol & has never missed a beat...
    If you don't want your's , I'll pay shipping !!
    dave
  5. upspirate
    upspirate
    Anyone have any experience with these? Seems like a deal with new cap & parts instead of rebuilding an old one (the points one Squirrel posted,For some reason this post didn't show his quote)
  6. gimpyshotrods
    gimpyshotrods
    Mallory is out of business. If you have a failure, it's over.
  7. Mr48chev
    I had a hell of a time getting parts for a Mallory 40 something years ago and I worked for a guy who set them up for the local racers then. Every time we needed anything for them we had to make a special trip across town to the one parts house/speed shop that stocked the parts.
  8. Stock HEI unit from your local wrecking yard.
    300cfm 4 brl ??
  9. Merlin
    Merlin
    from Inman, SC
    This.
  10. squirrel
    make sure it's not worn out. A lot of them were worn out when they were only 5 to 10 years old.
    also make sure it does not have the 4 wire computer plug.
    slack likes this.
  11. saltflats
    saltflats
    from Missouri
    I would put the point dist in it.
    You will have to maintain it but that will keep you in touch with your car.
    tractorguy likes this.
  12. Speedway sells one for 69.99. I've had one for 2 years and still runs fine.
  13. JeffB2
    JeffB2
    from Phoenix,AZ
  14. Kerrynzl
    Kerrynzl
    Use a GM HEI just check for excess play in the shaft [ this the only part that mechanically wears out ]
    Install a new MSD module [now available with a built in RPM limiter] and a new Cap with a Good coil and it'll be better than most of the Cheap "High Performance" HEI's from China.
    Here's the part to use
    https://www.summitracing.com/int/parts/msd-83647/overview/
    I used a MSD module for 20 years in my Road Racing BBC with a GM HEI, it has never missed a beat [I have turned it to 8k on a few occasions]
  15. slack likes this.
  16. squirrel
    The mechanical advance mechanism also wears out.
  17. Mr48chev
    The complete rebuilt is less money than buying a used one from the wrecking yard and replacing cap and rotor and module if needed in most cases for a general street driven rig.
