Auctions
Heavy Duty Frame Chassis Jig - Rotating
Discussion in '"The Antiquated" Classifieds' started by Kathy Widmann, Apr 25, 2021.
  1. Kathy Widmann
    Kathy Widmann
    City: West Bend
    State: Wisconsin
    Price: 1800.00
    Customer built blasted & epoxy coated 4"X4" support 3/4" welded plate on ends wich are machined square and located with dowel pins & 1/2" bolts to long 12' main supports.
    Measures: 44" X 12'
    The top surface was also blanchard ground after assembly for perfect square & flatness. Design is full rotational for ease of welding. Bolt on startionary legs also. Rides on steel swivel castors and screw down stops on end frames. Rotation ends are brass bushed.
    Will accept reasonable offer - pick up only in Wisconsin
    Mo rust likes this.
