Hot Rods Heater nipple cap?
Discussion in 'The Hokey Ass Message Board' started by Gus68, Sep 6, 2019.
  1. Gus68
    Gus68
    from Minnesota
    Ok. So here's a dumb one. So I have a 5/8 Heater hose nipple that I blocked off. Problem is I used those damn rubber caps and a hose clamp. While it looks alright, it doesn't last, starts to crack and leaks. And it doesn't seem to take verry long. Any better ideas? Something that's not big and clunky? Does any one offer a heavy duty one? Thanks fellas!
  2. Is it a threaded nipple ? Put a thd cap,or pull it replace with thd plug.
    Black_Sheep and flatford39 like this.
  3. 34Phil
    34Phil
    bait well plug?[​IMG]Or use a loop of hose to other heater nipple.
  4. 325w
    325w
    from texas
    Find a brass plug with an Allen head in it. Might have to use a bushing if you can't find a plug big enough.
  5. Gus68
    Gus68
    from Minnesota
    No it's an extra nipple in the radiator. I think it was ment for a heater hose but I'm not using it
  6. 33EB4286-5580-4886-9075-0A9AE57FAC11.png These are advertised as heater bypass caps, maybe they’re different/better than what you already tried?
  7. goldmountain
    goldmountain
    scotty t and WB69 like this.
  8. Paul
    Paul
    Editor
    Use a 1/2" copper pipe cap in a short piece of 5/8" hose..
    oh, you said not (dumb) and clunky..
    loudbang and Texas Webb like this.
  9. BJR
    BJR
    Short piece of correct size hose, bolt the fits tight in hose and 2 clamps. Done.
  10. DIYGUY
    DIYGUY
    from West, TX
    I’ll never use the “ heater bypass caps” again. Had one blow up and caused me a roadside repair. I’ll take dumb and clunky if it works
  11. Joe H
    Joe H
    If it's an aluminum nipple, just thread it and screw a pipe plug in.
  12. BamaMav
    BamaMav
    from Berry, AL
    I used the same caps that scotty t posted, they last about a year before they crack and leak.
    olscrounger likes this.
  13. s55mercury66
    s55mercury66
    from SW Wyoming
    One more of us who has had no luck with the rubber caps, so the clunky bolt-in-the-hose deal it is for me. I'm a relocated hillbilly anyway.
  14. Gus68
    Gus68
    from Minnesota
    Yup that's me. Hate the rubber caps that crack. But I'm not liking the bolt in the hose deal.
  15. egads
    egads
    I have been using silicone blanking cap's. Haven't had any more problem's.[​IMG]
  16. WB69
    WB69
    Liking the solder or plug ideas myself.
  17. big john d
    big john d
    from ma
    a bolt in the hose will look much better if you use an allen head bolt instead of a hex head one
  18. BJR
    BJR
    Or use a chrome allen head bolt.:D
  19. Is there any way you can use it for it’s intended purpose? It was put there for a reason.
  20. BamaMav
    BamaMav
    from Berry, AL
    I looked for something like that but never found any. They should outlast the crappy rubber ones easily.
