Technical Heat gun recommendations??
Discussion in 'The Hokey Ass Message Board' started by hotrodA, Jan 7, 2020.
  1. mike in tucson
    mike in tucson
    from Tucson
    We have seven or eight Milwaukee corded guns that work great. We just got two Milwaukee battery guns to experiment with. Battery heat guns are attractive if you are working underneath something and don't want the hassle of a cord in the way OR if you need to do a quickie one or two heatshrinks. The battery gun heats fairly quickly but we have not counted how long the battery lasts.
  2. lemondana
    lemondana
    from Lincoln NE
    HF are cheap enough, buy two and when the first one burns out you have another. My first one lasted 6 or 7 years.
    bedwards, upspirate and JeffB2 like this.
  3. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    HF heat gun works just fine.
    But most often I use my cordless BIC lighter.
    No bulk, no heat up time, no cool down time, fits in my pocket and many compact spaces.
  4. indyjps
    indyjps
    Jeez, I use a lighter on shrink tube, even though I own a heat gun, never occurred to me.o_O
  5. Black_Sheep
    Black_Sheep
  6. Early Ironman
    Early Ironman
    [​IMG][​IMG]
    These are what I use the most.
    The butane Weller is extremely useful. It has a tiny heat gun attachment. Perfect for working in confined spaces.
  7. I always used the wife's hair drier but when I decided to rewire the Olds I bought one of those HF heat guns. It worked good until it was out of warranty, then it burned up! I went back to using her hair drier...
    JeffB2 likes this.
  8. alanp561
    alanp561
    40 year old Craftsman. Still working
  9. error404
    error404
    from CA
    with the little torches, is it difficult to keep the wire insulation (and shrink tubing!) from bubbling or burning? Or is it pretty forgiving?
  10. Mimilan
    Mimilan
    Next time you have one fail...... buy a cheap hot-air plastic welder.
    https://www.amazon.com/Ridgeyard-Professional-Plastic-Welder-Welding/dp/B01N7P477H
    These have temp settings and a zero temp to cool them off.
    If you follow the cool down procedure it will last for years.
    Plus you can learn to plastic weld like I did [​IMG]
    The biggest use for my Leister is removing "rubber marbles" off racing slicks with hot air and a scraper.
    Be careful though........You can start a fire with these
    David Gersic likes this.
  11. WB69
    WB69
    Have used both heat gun and micro-torch. Each kind of has its place. Really like the click on, click off of the micro-torch though.
  12. Early Ironman
    Early Ironman
    The Weller butane torch is very forgiving.
    With the heat gun attachment. It won’t melt the tubing or insulation unless you hold it in one spot too long. There is no flame coming out. Just the heat from the diffused flame inside the tip.
    WB69 likes this.
  13. Rramjet1
    Rramjet1
    I race radio controlled cars and the Weller is a perfect tool for work at the track, particularly if you don’t have electricity.
    Early Ironman likes this.
  14. error404
    error404
    from CA
    Thank you :) I might try one of these for working in tight spaces under the dash.
  15. Thanks for all the responses! Those battery powered ones are intriguing.
  16. Thanks for all the suggestions!
  17. stuart in mn
    stuart in mn
    I've had a Milwaukee heat gun for ages, still works great. You can also use them for stripping paint (and thawing frozen pipes in the house), so they're not just for heat shrink tubing.
