Headliner in a 64 galaxie
Discussion in 'The Hokey Ass Message Board' started by Tommyk74, Aug 28, 2013.
  1. Tommyk74
    Tommyk74
    from Nashville
    I have a bowtype headliner in my car. The one in the car is starting to give way I want to replace it. Can this job be done with the glass in the car. Any tips for the job would help thanks
  2. 56premiere
    56premiere
    If there is screw on trim fr and rr, yes. I believe that is how the 64 is. Keep track of which bow goes where, I usually file notches, 123 etc in the ends.. Jack
  3. the trim is pictured here
  4. JB_roadrage
    JB_roadrage
    Looks to me that the rear window has to come out.. but I've been wrong before...
  5. I had a headliner put in a 63 Galaxie years back and they did not have to take out any glass. Should be the same for a 64. I had it done because I did not want to fool with it. I did one once before and found out I wasn't very good at it.
  6. JB_roadrage
    JB_roadrage
    Hold on... looking at the first picture again I believe I see screws in the trim... so I reckon I was wrong..
  7. joe--h
    joe--h
    from New Mexico
    Don't know about the glass, looks like the rear needs out. BUT, for an absolutely perfect factory fabric match and a perfect fit Acme Headliner in Long Beach CA is the place. And you have 2 cars needing a headliner? Joe H
  8. crazy_tonguezz
    crazy_tonguezz
    from glendale
    The back window does not have to come out!
    For sure like 56premiere said keep track of where your bows come out from not only in what order front to back. but also what hole , normally there is 3 or so holes that the bow can go into. I use a sharpie and circle around the rods before i even pull them out and label them front to back.
    those headliners are like window tinting work from the center out. Just take your time and dont rush it. want a great hint. leave all doors open and put a fan by the door cause you will sweat like bacon!! and want to rush the job.
  9. 56premiere
    56premiere
    No, you won't take the glass out of that car. The next warning is be very sure to mark or some how remember what length screw goes where. They will puncture the roof if to long. Jack
  10. An old timer thathas been doing interiors for 50 years told me that he always wraps masking tape all around the bows then inserts them into the headliner. Says it allows the material to slide easier and not get hung up.
    If you can find an assembly book from Ford it will give you the step by step instructions for installing the headliner.
  11. TooManyFords
    TooManyFords
    from Peotone IL
    No glass has to come out. Had one put in my 64 a few years ago.
  12. crazy_tonguezz
    crazy_tonguezz
    from glendale
    56premiere touched a very important sucbject, screws in the right place.
    Cut a piece of cardboard, mark it with sharpie FRONT and you take a screw out stab it into the carboard in the order you take it out from.
    You can get all fancy and draw a picture of the trim if it makes it easier for you to visualize.
