HEADERS! Let's see'em
Discussion in 'The Hokey Ass Message Board' started by freiertpc, Nov 19, 2009.
  1. 1933 DeSoto with DeSoto HEMI....I love these little stubbies....
  2. spikeshotrods
    spikeshotrods
    Here's mine, built from a set of over transom Basset boat headers
  3. Some I made using J bends from Summit.
    I still need to add one more tube per side.
    :D
    Sam
  4. river1
    river1
    nice work, as usual, Sam
    later jim
  5. Thanks Jim!
    I try to match the tubes up perfectly... then TIG weld them... file the welds down and then use emory cloth to finish the joint off.
    Makes it look like the tube is one piece.
    Right now they are up in Redding getting coated along with the rest of the exhaust.
    Sam
  6. desotot
    desotot
    made these for my 425 nailhead in my 49 merc
    I couldn,t fit an exhaust manifold on the driver side to clear the power box so I had some 1 1/2" mandrel bends left over from my desoto hemi project that didn't get used so I put them to use on the nailhead.
  7. Marty Strode
    Marty Strode
    Built these on a 36 Ford Phaeton.
  8. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    Very very nicely done!!!
  9. Bigbangtheory
    Bigbangtheory
    from ohio
    Hope this works. Never did this before. This is a pic of the headers on my 32 5window. They were made from motorcycle exhaust.
  10. roseboystoys
    roseboystoys
    These are mine...Before and after....
  11. CheatersPete
    CheatersPete
    Mine... done last week
  12. brownsmetal
    brownsmetal
    What are you pro header builders using for bends? Any mandrel bent bends that I have bought are not consistent in od through the bends. If I cut and peice the od's are always off. I compensate for this by making the part of the tubes line up where you can see it but the back side always looks like shit. How do you compensate or is there a known better quality bends? Thanks
  13. FEDER
    FEDER
    Did these on My racecar a while back. fed
  14. 4tford
    4tford
    40 ford
