Hot Rods Head studs/dowels
Discussion in 'The Hokey Ass Message Board' started by junkyardgenius, Jun 18, 2018.
  1. junkyardgenius
    junkyardgenius
    from Kernow
    Just wondering if you still need to run the locating studs for cylinder heads if you are using studs instead of bolts?
  2. saltflats
    saltflats
    from Missouri
  3. Beanscoot
    Beanscoot
    Since we don't know what the engine is, we can only generalize.
    Pretty much any engine I can think of has clearance around the head bolts or studs, and the actual precise locating is done by the dowels.
    So the dowels should be used even with head studs.
  4. Mike VV
    Mike VV
    from SoCal
    Yes, use the dowels also.
    Most studs are NOT for 'locating" the head.
    Mike
  5. junkyardgenius
    junkyardgenius
    from Kernow
    Thanks for the replies. I,m just going to order some dowels.Thought I had all the bits I needed for my rebuild but forgot about the dowels.
    It’s a 354 Hemi.
