Technical Head light switch for a '54 Ford converted to 12v
Discussion in 'The Hokey Ass Message Board' started by 51504bat, Aug 8, 2019.
  1. 51504bat
    51504bat
    Posted this on the Barn but I thought I'd ask over here as well. I couldn't find anything in the archives but maybe I didn't word the question correctly. That said, Getting ready to completely rewire my '54 Ranch Wagon and convert it to 12 volts. I've read conflicting opinions on using the stock '54 6 volt headlight switch vs. using a 12 volt one from a '56/57. From what I can tell the 12 volt switch will accept the knob assembly from the '54 switch and the 12 volt unit will install with no mods where the 6 volt switch was. C&G said the '54 switch should work fine but I'm a little concerned about how the dash light dimmer rheostat in the 6 volt switch will work with 12 volts. Am I worrying about nothing or should I go with the 12 volt switch?
  2. It's all about amps, and the 6 volt switch will see a lower amp load on 12 volts. So no problem!
  3. atch
    atch
    Just to reinforce what Steve said: Clarence (see avatar) was converted to 12V in 1991. I used the original 1948 headlight switch until 2017, when I replaced it. The old one failed, but not because of voltage or amperage; it was just worn out. The switch was 69 years old and had about a gazillion on/off cycles on it.
    51504bat likes this.
  4. morac41
    morac41
    Steve x 2 ...if you are worried use the switch to operate a relay to control the head lights
    51504bat and JeffB2 like this.
  5. The other thing that should be mentioned is the current aftermarket/replacement headlight switches generally aren't as well made as the OEM ones, so if yours is OEM and still working well it'll probably be better quality.
  6. I have to agree with the above. I remember doing at least 3, 6 - 12 V conversions using the Ford 6 volt switches and having no problems. As Steve has said, there is less current with 12 volts so a 6 volt switch will handle the load quite well.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    scrap metal 48 and 51504bat like this.
  8. 51504bat
    51504bat
    Thanks for all the good info.
  9. When we rewired our '54 Ranch Wagon I just replaced the headlight switch with a new one, the original knob worked fine.
    I did relocate the placement but the principle is the same.HRP
    OLSKOOL57 likes this.
