Projects Haulin' ass in fiberglass
Discussion in 'The Hokey Ass Message Board' started by Mr T body, Nov 1, 2017.
  1. AHotRod
    AHotRod
    I made some modifications to my homemade 'glass Model A Coupe body recently and used Turtle Wax as my release agent, worked perfectly
  2. DDDenny
    I used K-Y jelly once!
  3. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Wrong type of release
  4. pirate
    pirate
    from Alabama
    Not trying to be picky and also you mentioned you were not done but the placement of the seat belt anchor brackets appears to be too far forward. The lap belt should lay flat across your hip bones or pelvis to far forward and they pull down on legs too far back your pelvic bone slid under belt causing internal injuries. Most seat belt manufacturers have very specific directions for mounting. Went through all of this with tech inspector for sports car I built. If your going to have them they should provide as much safety as possible.
    loudbang and alanp561 like this.
  5. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Good catch. That's v1.0 and I think I've changed the anchor design 3 or 4 times since then. To get the right angle on the lap belt I will wind up putting a gusset in where the forward hoop of the cage meets the floor to anchor the belt.
  6. pirate
    pirate
    from Alabama
    If you put in a cross bar (harness bar) in the hoop it should be no lower then two inches below the top of your shoulders when sitting in seat. Lower then that can cause compression of the spine in a roll over or front end impact. Higher then that and the belt may slide off your shoulder in a side impact. Again the manufacturer will have recommendations. No one plans on accidents and the real need fo seatbelts but the seatbelts can actually cause injuries if not installed properly.
  7. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    There's actually an extensive write up on Pirate 4x4 on properly mounting harnesses and that's one of the points. One of the crossbars will be at shoulder level and tabbed (don't like the idea of looping). There'll a few things I'm doing that aren't "normal", but I'm over-engineering the cage just in case I get on my head.
  8. patterg2003
    patterg2003
    The mock up was a large piece so I misted it with primer to block it out to fix the high and lows. Once it was smooth then I was happy with that. I waxed over bondo & all as it was a one shot deal. There were no issues with the formed glass. Worked good. You are using wood. An old carpenter showed me that he used bondo like plastic wood to fix damage on wood parts that was going to be painted. The bondo set quick and was easy to sand smooth to level the wood. I have used that a few times with good success. I think the wax is a good barrier and for a one off then I don't think paint is necessary unless you are sanding and looking for imperfections. If you are comfortable that you have the smooth shape then paint is not necessary.
    Mr T body and loudbang like this.
  9. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    The corvette pissed me off yesterday over replacing a simple rag joint, so today was doing something more redeeming (and cleaner).
    Took a while to come to terms with just what reference the door hinges should swing from, but decided it had to be parallel to the top and bottom of the door. The hinges will be tabbed off the 2nd hoop of the roll cage, so first thing was put the upper and lower hinges swinging on the same plane with something I can mount adjust-ably.
    Playing with the cutoff saw and mig is far more fun than crawling around under a 45 year old dirty, greasy car for 5 hours.
    swade41, OFT, loudbang and 3 others like this.
  10. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    So, like so many other things on this car, I didn't like how little flexibility the 2x2 placement gave me, so went back to the drawing board. Same basic design, but moved the 2x2 toward the rear so I can move the pivot point closer to the door edge. Made a pillar with the other hinges and the centerline was ever so slightly off making the hinge arms swing off plane. Spent last night machining a fixture to mount the hinges for welding so I know the pivot centerlines are perfect. This is why you just tack these things together..... easier to cut spot weld than a finish weld.
  11. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    This is about as high tech and precision as I get. The bottom blocks are within a few thou of each other and the back as well. Clamp the hinges in using the blocks and back of the angle to hold the centerline then tack it in. Done.
    OFT, AHotRod, loudbang and 1 other person like this.
  12. shortypu
    shortypu
    Man that big block Ford looks good in their.
  13. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Sometimes the little things get you over the hump and get you motivated again.
    Got the B pillar done and the body cut out for the hinges to clear today. Kinda cool when it actually starts to look like a car (at least until I tear it apart again) door7.jpg door8.jpg door9.jpg
    shortypu, saltflats, rjgideon and 2 others like this.
  14. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    OK, so I know I haven't even started the fiberglass work yet, but the brain has gone off on a tangent and I need some help from the board. The window glass and channels need to be made from scratch and I've never done a fiberglass door. The glass is tapered but must be stable going up and down in the channels so I'm assuming the sides of the lower portion of the glass needs to be parallel.... question is how tall does the parallel section need to be ? With the tapered portion 13" tall, do I need 13" of parallel or how much less? Concerns are I can't go MORE than 13" because of the height of the door, and less glass means less weight.
  15. AHotRod
    AHotRod
    Pickup scissors or a razor blade, large piece of cardboard and start making patterns, that is what I do until I see what will work.
  16. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    I get what you're saying but it's kind of a cart before the horse kinda thing. I would need to have the channels in to determine how long the parallel section must be to be stable, which tells me how long the channels have to be.
  17. AHotRod
    AHotRod
    Do you have the window regulators in?
    If so, that will give you a measurement as to how tall the window can be.
    Once that has been determined, your pattern with the curved area is cut and the remainder is your straight section.
    It should work out just fine.
  18. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Did some digging around and Hagan has a window kit with instructions that say the straight section of glass should be between 2-7". I'm leaning toward 5-7" to keep the glass from rocking in the channel. Now to get some u-channel and start fabbing up some mounting brackets I can rivet them to.
    loudbang and pprather like this.
  19. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Haven't made up my mind yet on using a regulator or strap. The type of regulator I would use isn't HAMB friendly.
  20. DDDenny
    I use heavy cardboard for a rough-in pattern then transfer that to Masonite, I've had much better luck with Masonite over heavy cardboard for making glass patterns, it maintains its shape much better through the process, won't buckle and bind when testing in the channels.
    I made a small opening in the Masonite for a handhold for raising and lowering during testing when I converted to one piece glass on my 66 Suburban, also used a universal power window unit from Specialty Power Windows, nicely engineered, though I'm sure they are not part of your plan for this car.
  21. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Actually I do have a SPW universal kit in mind for it. It's a bit of a concession to it being somewhat streetable. It HAS to have the ability to lower the windows.
    You guys don't EVEN want to know what I'm doing for a rear view (non) mirror.......
  22. AHotRod
    AHotRod
    I mix up epoxy and glue to channel directly to the fiberglass.
  23. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Been going back and forth with bolting or epoxying the channel brackets in place. Gonna be a lot of head scratching when that time comes.
  24. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Bought myself a Xmas present today. Was having trouble fitting the doors as the edges were still as cut from the mold. Bought a hand held belt sander and got the gaps pretty close. Handles and latches coming, so trying to figure where the outside handle should be mounted. Major case of the itches today too.......
    shortypu, wicarnut, OFT and 3 others like this.
  25. flatheadgary
    flatheadgary
    from boron,ca
    look at it this way, by the time you are done, you will be acclimated to 'glass work and you can build that t bucket you've always wanted. hahaha
    AHotRod, OFT and loudbang like this.
  26. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    So here's how it starts. Happened on most every car I've ever built so I SHOULD know better. Since all the linkage parts of the handle and latch are custom I have to get a little creative. Needed a longer striker than the normal ones, so dug out a 3/8" bolt (only have stainless around), sourced a sleeve to match the latch and then made the handle backing plate that'll be epoxied to the inside of the door skin for strength. Waiting for the other materials I'm modifying for the handle arms, so started working on the striker. Cut the hex head down to size and figured it's stainless, so.....
    saltflats, rjgideon, OFT and 2 others like this.
  27. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Next piece of the puzzle. I'm using flexible weatherstrip channel so wanted a rigid mount for it. Sourced some aluminum C channel (would have preferred steel, but apparently there's no such thing in the lengths I need) that'll mount inside the doors and just rivet the weatherstrip to it in case I need to service it later. Should be a nice factory-ish looking install with little flex and no rattles. ws1.jpg
  28. rjgideon
    rjgideon
    Great idea! Thanks for sharing your progress!
  29. 3banjos
    3banjos
    from NZ
    A friend uses small box section for channel. Bends to shape, then plasma cuts the inside edge off. Easier to mig tabs to, bolt to inner structure and glassed in place. Sadly all my old photo's got lost when computer crashed.
  30. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Steel channel would have been nice, but wasn't a deal breaker. I heard a few guys glassed the brackets to the door and I might do that depending on how much gap there is between the channel and door. I want as much adjust-ability as I can get without complicating the hell out of this. I want the chrome bead of the weatherstrip to be nice and tight around the window opening, so we'll see when I start laying it out.
