Has anyone ever rodded a big truck?
Discussion in 'The Hokey Ass Message Board' started by J Man, Mar 26, 2007.
  1. J Man
    J Man
    I am speaking ore of the 1 ton and bigger trucks. Wether they were turnd into flatbeds, car haulers or whatever. Lets see some pics if anyone has any as well.
  2. Rande
    Rande
    Here's a Diamond T thats heading for the crusher. Would make a very cool flatbed.
  3. NITROFC
    NITROFC
    Check in the archives ..there are a few posts on COE trucks
  4. Goztrider
    Goztrider
    from Tulsa, OK
    I'm building a '29 Ford Model AA truck. 14 spring leaves up front, 16 in the rear.
  5. J Man
    J Man
    That would suck if it got crushed.
  6. J Man
    J Man
  7. 47fordcoe
    47fordcoe
    from San Diego
    I building a 40 GMC COE..........ford wide fives.....31 Model A rear end..cadillac flathead V8 mid engine....chopped and dropped......but I can't post pics......I'm only in the day dreaming stages right now. I have all the wide 5 stuff the rear end and the cab I'm looking for an early caddi v8..this should be a pretty cool ol truck..
  8. Goztrider
    Goztrider
    from Tulsa, OK
    Its still on the trailer, but I'm getting ready!
  9. panhead_pete
    panhead_pete
    Here's mine just after I got it home.
    It wont be rodded as it is. Been stripped and the cowl etc will go into a little pick up. Man the chassis was REALLY REALLY heavy as were all the other pieces that came off it.
    Nearly dropped the chassis on me on the weekend too - very lucky. :eek:
  10. egg man
    egg man
    from IN.
    I have 3 .2 48 coe ford and a 52 fire truck
  11. InDaShop
    InDaShop
    from Houston
    We were looking for one of those forever. Found one just south of Jonesboro, Arkansas. Then the deal fell through. Plan was to narrow the cab and make the split rear windows 1 bigger window.
    Anyway, here's my current InDaWorx's
  12. 47fordcoe
    47fordcoe
    from San Diego
    Is that a cadillac flathead in the truck............I like what I see!!!
  13. old beet
    old beet
    Look up Tyrone Malone for big hot rod trucks!!.........OLDBEET
  14. Appleseed
    Appleseed
    Anyone save that thread that had pics from the Chrome Shop Mafia. Oh hell, just look up those guys for sure. That thread had some really cool rigs.
  15. TimDavis
    TimDavis
    Pete Eastwood has a bitchin' big Deuce flatbed.
  16. gahi
    gahi
    from Moab, UT
  17. OFT
    OFT
    I have a '29AA that started life as a 2 1/4 ton. It is a 1 1/2 ton now. Would post pic's, just do not know how. Anycase I have owned the old funky truck (OFT) for nearly 40 years.
    Spec's now are 454 BBC, TH400 (put in in 1975 rebuilt in 2005). '32 fat beam offset drilled to take '58 Chevy 38 series king pins. Home brew disk brake kit for front using 4x4 front rotors and cailbers. Hubs drilled out to take 9/16 studs.
    Rear is a corp 14 bolt C&C (cab and chassis) with a blackbird custom rear disk kit. Rear springs are the '58 Chev 38 with overloads taken off. Uses 1500lb air springs instead.
    Much more done, but you get the idea. I tow a 37' 5th wheel RV (yep, it is a big-un, over 10,000lbs).
    Earl
  18. pistinbroke
    pistinbroke
    Where did you find a four door coe??? I would love to find a 38 Ford four door coe. These ones look great!!!
  19. 49willard
    49willard
    from Maine
    You need to fabricate it. That is what egg man did. Several cabs and a ton of talent. His work is phenomenal.
  20. Damn Old Beet, I havent heard that name since the Early 80's when he put
    on a show at the tire shop in Auburn. Thanks
    I wanted to be a truck driver for about
    6mo after that.
  21. J Man
    J Man
    Are brake parts easy to find for these big old trucks or is it easier to just swap out the chassis?
  22. Primo
    Primo
    Wish I lived close enough to snag that one, it would make an awesome hauler
  23. brjnelson
    brjnelson
    Here is my latest project, I got a 292 installed and now I am working on the 4 bar and air bag suspension.
    Jman I have found that most of the truck brake and suspension parts are around, for popular makes. Most trucks have a 34 inch wide frame and are a EZ frame swap. My dad is swapping a 54 Ford COE onto a motor home chassis.
  24. Dan Warner
    Dan Warner
    from so cal
    Search the Internet for The Phoenix of Carl Heap. Absolutly the best hot rodded BIG truck.
    DW
  25. publicenemy1925
    publicenemy1925
    from OKC, OK
    Totally cool Diamond T.
  26. Toymaker
    Toymaker
    from Fresno,CA
    One of my Projects... A Bit NEW but the square cab gives it a Traditional look. Building a 4 link rear suspension, adding Super Single rear tire and wheels, 5 speed Trans, building it to go Drag Racing.
  27. Goztrider
    Goztrider
    from Tulsa, OK
    I'm changing out the suspension under my Dubble A and going with converting '42-'46 front spindles (and discs) and a later model Ford 9" rear with parallel leaf springs. I'm still going to do a custom wooden dump flatbed on it, but it'll be just for shits and giggles. The rest of the truck is going to be a blast.
    Here's a picture of my Dubble A and my '29 RPU.
  28. Silhouettes 57
    Silhouettes 57
    Do you mean something like this?
    This is an Idaho Motor Home.:D
      44.5 KB
  29. TxRat
    TxRat
    Mine started life as an 1 1/2 ton oil field truck in San Marcus. It had a flatbed and dual wheel axle..
  30. fiat128
    fiat128
    from El Paso TX
    I've posted this before but here's my project, a 34 International 2 ton truck.
    The back of this thing was so heavy I had to cut it off just to keep from blowing out the tires on the trailer.
    The frame was a lot heavier so I plan to make a 2X4 box frame but the cab, grille, etc. are the same as a pickup, which is what I am going to make it into.
    I am planning to use brakes from a late 40s ford or if I can find some Buick parts (I'm new at this so I'm not the best resource). I have a whole bunch of late 50s Alfa Romeos that have these huge finned aluminum drums on them that may work (I was going to investigate that later after I get further into the project). Anyhow, I have no plans to use the ones that came on the truck, they are too big.
    I think there are quite a few of these around.
