A few years ago I picked up this Halibrand center section, spool and side plates, later bout the axles tubes and frankland drums and a second spool from a man on ebay. the side covers have a secondary ring in them that apears to be the same bolt pattern as a banjo. I am looking for any info i can get on the thing or specs or what parts i can get to fix it from someone like winters. A phone call to Halibrands tech dept turned into a " we never made that rear end send it in for use to authenticate". If better photos are needed ask away. thanks in advance. Chris <center> <br /><br /> <br /><br /> <br /><br /> <br /><br /> <br /><br /> </center>
The center is for 12 bolt sideplates and the adapters for the tubes are 11. Look for an 11 bolt center, Frankland and winters made those as well as Halibrand---Halibrands are harder to find but the others are not. You can redrill the adapter sideplates to fit the 12 bolt center--but you'll wish you hadn't. SPEEDWAY ENGINEERING ---CALL THOSE GUYS.
Thanks for the info Brian, i will give speedway engineering a call tomorrow, i need to order a sway bar from them anyways
