Halibrand quick change
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by longagoracer, Oct 18, 2020.
  1. longagoracer
    longagoracer
    Hi,
    Another newby from Alberta!
    I'm in the early stages of restoring a sprint car built in 1965 by Grant King. It has a Halibrand quick change diff. I had an awful time getting the rear cover off - no way would a gear change ever be "quick." I thought that the problem was bent studs, but no, once I got the cover off it turns out that one of the two shafts is .001" wider than the other. I would call it a machine-press fit. Has anyone familiar with Halibrands ever come across this issue? My best guess is that there was damage at some point and a new shaft was poorly machined. Ever heard of Halibrand turning out a diff with such a flaw?
    Any thoughts would be appreciated.
  2. You need to ask this on the main discussion forum, not here in the intro section.
