Technical Halibrand QC ID and Tech Help
Discussion in 'The Hokey Ass Message Board' started by vintagerod, Mar 4, 2019.
  1. Yes
    0 vote(s)
    0.0%
  2. No
    1 vote(s)
    100.0%
  1. vintagerod
    vintagerod
    from Midwest
    I recieved these Halibrand parts from an old friend; drum brakes, spool, grimy. I think I have most parts, except good bearings and housings.
    There must be great ID people on this forum.
    So which housings for a Model A?
    Best place to get parts, bearings, etc?
    Looks traditional, is it worth it?
    Any help would be appreciated.
  2. Pete Eastwood
    Pete Eastwood
    from california
    that's a typical Halibrand V8 QC center section .
  3. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    As Pete said, V8 Halibrand center. The rear cover says Culver City, that's the early one. The open drive is a home made unit. The hubs are not a matched pair.
    You need to get that thing apart, clean it up and lay out all the parts you have.
    I would not run a spool on the street.
    You cannot use Model A axle trumpets with the V8 center.
    All the bearings are available.
    You can upgrade in several areas.
    Yes, it's worth it!!!!!
