Halibrand 101 bearings
Discussion in 'The Hokey Ass Message Board' started by Reddy, Dec 22, 2012.
  1. Reddy
    Reddy
    Hi,
    I'm working on a 101 Halibrand QC and need the numbers of the two bearing for the lower shaft.
    Thank you Mike
  2. noboD
    noboD
    Take the old ones to a bearing house. They will measure them and give you what you need.
  3. Reddy
    Reddy
    I have the 101 housing and the lower shaft but no bearing to get the numbers off of.
    Mike
  4. 51 mercules
    51 mercules
    I'm in the same boat. Did you ever get the bearing numbers? Thank you!
  5. Speedwrench
    Speedwrench
    Have a bearing house cross reference these numbers.
    lower shaft front 62o6 ZJ
    lower shaft rear 6306 ZJ
    According to my early 70's Halibrand catalog these are what you need for an H101 case.
    Tim likes this.
  6. 51 mercules
    51 mercules
    Thank you!
    Speedwrench likes this.
  7. clays diff
    clays diff
    what you need is a 206L and a 306L the L means it is a sealed bearing on one side
  8. jimmy six
    jimmy six
    Different brands have different letters for seals or shields. 206 and 306 are standard #’s. SKF used a 6 in front of a lot of theirs as I remember.
  9. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Not a H101 expert, but I use a double sealed bearing at the front lower shaft location and double shields at the rear on all my QC's.
    Do not worry, both bearings will have adequate lube. The shields will protect the bearing from debris.
  10. 51 mercules
    51 mercules
    Thank you for all the info!
