I was pulling apart a shoebox Ford that had its share of questionable work done to it, but this one just made me laugh. I figured you guys would get a kick out of this, so post up your own pics and stories:
That's great. I appreciate the fact that the repair was completed with a "tall boy" can rather than just half assing it with a 12 ounce.
I had trouble making that out too. That is a muffler on the left and that other stuff is supposed to be exhaust tubing. This is unbelievable without a picture but I forgot where I put the piece that I took off of this seat. (But I did keep it for an anvil.) For a seat bracket it had a piece of 4" steel channel (like a boat trailer frame) bolted to the slider from the front to the back. And it wasn't even real channel. It was a piece of 2"x 4" angle iron with a piece of flat iron welded on the other side. It had about 10" bolts that went all the way down through the frame.
When i was young with empty pockets I had a car with leaking battery This made a rusty hole behind the battery housing (bracket ?) At this time I didn’t know how to do Sheet metal repair Had no fiberglass and no money to buy Just funny idea I’ve got : Took toilet paper as fiberglass and putted polyester resin on it After a small paint job the result was fine Sorry i didn’t take pics (it was 30+ years ago)
Once years ago, I worked on an off topic vw bug. The brake line runs from the front to the rear inside the car along the center hump, and usually rusted out. Someone had used a section of air hose to go from the gas pedal to the rear. Sorry, no pix on that one. Why are my brakes spongy?
I bought a ‘34 coupe last year. I’m finally digging into it. The frame was painted black and looked decent from what I could see. Turns out it had filler hiding some heavy pitting along with poor fish plating over old corrosion. I removed the plating , all the rivets and pulled the frame apart to get blasted. It’s going to need some work to get right but deserves it. Sent from my iPhone using H.A.M.B.
When you put that all back together, you will need something better than 2 saw horses. Like a frame jig or a homemade one, so it doesn't have a twist in it, and is square.
No pics but had an old truck come in a customer had bought complaining of how it drove. Said seller told hun it had been wrecked but fixed. Sure enough I climb under it and see no damage anywhere. So co worker pulls it on machine and takes alignment readings and they are a mile off. And even worse it won't come close adjusting it. So co worker lays down under it and starts feeling around. He starts pulling black permatex up to 1/2" thick out of wrinkles in the frame! They had filled wrinkles with permatex and smoothed it all out and undercoated frame with a nice coat of satin black on top of that. Alot of work for "rubber bondo" !!
When I was taking the rear quarters off of the Studebaker (they bolt on) I knew I had all of the bolts out and the quarter was still "stuck". I kept tugging on it and it finally came loose. There was a big rust hole in the quarter (and inner quarter) that had been stuffed with bondo and newspaper. Sorry, no picture. The seller gave me decent quarters and Classic Enterprises sold me lots more replacement metal, Studebakers really help the economy when you start to fix all of the rust. The red primer covered the surface rust over the whole car.
