Grinding Welds?
Discussion in 'The Hokey Ass Message Board' started by gunk, Mar 18, 2009.
  1. gunk
    gunk
    from phoenix
    I kinda like the look of the welds being exposed on some parts of the car. My question is do welds have to been ground down?
  2. Anderson
    Anderson
    No.....I'd rather have a good looking weld than a ground down ugly one. My welds are usually all ugly....
    BTW, is the frame jacked up and the rear end hanging down in that picture?
  3. Those are good looking welds, leave em.
  4. lakester47
    lakester47
    I think your welds look terrific and no they don't need to be ground. I like seeing the craftsmanship in a car. If the rest of your car looks as good as this corner, you have a cool ride.
  5. PeteFromTexas
    PeteFromTexas
    Hahaha Me too!
  6. SaltCityCustoms
    SaltCityCustoms
    2nd.
  7. hemi guy 53
    hemi guy 53
    from colorado
    do good prep work, make a nice weld and leave it alone. It looks better and is stronger
  8. gunk
    gunk
    from phoenix
    The rear bones havn't been mounted yet, so the diff is pointing up a bit.
    If something looks wrong please let me know. This is my first rod build.
    Thanks.
  9. choppintops
    choppintops
    Nope, they don't. Too many guys seem to spend more time practicing on their grinder when they should practice their welding.
  10. PK
    PK
    from Ohio
    Nice work... I'd leave the welds as is.
    PK
  11. Anderson
    Anderson
    Your shackles are pointing the wrong direction. The spring needs to be hanging below the perches.
  12. terry k
    terry k
    from toledo oh
    How will that spring work with the shackles bottomed out?
  13. Welds are much stronger if you DON'T grind them , And yours look fine. Nothing to be ashamed of there!
    And as mentioned above, the shackles need to point the other way.
  14. KeithDyer
    KeithDyer
    Once you start grinding welds, you can't quit grinding welds.
    They will never look nice no matter how much you grind them.
    It will take Bondo or some kind of filler to make it look right.
    Take the time to make a good weld and leave them in an as-welded condition!!
    K
  15. choppintops
    choppintops
    They arent bottomed out. They are "flipped" upward. My guess he has it that way to stay more rigid during set up.
  16. gunk
    gunk
    from phoenix
    They where hung up. See latest pic. But now the way it sits, the bottom of the spring perch is hits the diff:mad:
  17. NTAPHSE
    NTAPHSE
    Maybe once you clean all the grease of that axle it will clear. :)
  18. gunk
    gunk
    from phoenix
    Or maybe it will help it slip by:eek: I think once I get the bones+shocks mounted it should clear.
  19. thunderbirdesq
    thunderbirdesq
    Whoops!:eek:
  20. T McG
    T McG
    from Phoenix
    Read my signature
  21. BBYBMR
    BBYBMR
    If my welds looked like that, I wouldn't grind mine -
  22. gunk
    gunk
    from phoenix
    I can't take credit for the welds they where done by az/willis....the kid is good.....my welding is improving.
  23. Kenneth S
    Kenneth S
    With welds that look like that, it should be a crime if they were to be ground on, and or filled with bondo.
  24. vinnymac44
    vinnymac44
    from W. Oregon
    Beautiful welds are a thing to look at and all should see.
  25. speedmetal
    speedmetal
    from houston
    i wounld grind those. they look good and anytime you grind a weld that hasnt been bevelled befroe hand you ruin its integerty.
  26. zibo
    zibo
    from dago ca
    If you used a 110V welder than the welds shouldn't be ground down especially.
    TP
  27. Mr. Weld
    Mr. Weld
    If they look good leave them alone.. If the joint is prepped to get good penetration the weld should be as strong or in some cases stronger than the parent material. Make sure you have no undercut along the edges, this will make the weld weak and a likely place for a crack to start.. Looks good from what I can tell in the pic.
  28. J'st Wandering
    J'st Wandering
    A ground weld is someone covering up a bad weld. Not always but more times than not the case.
    Neal
  29. az/willis
    az/willis
    it wont hit once your bones are on and the pinion angel is fixed,, trust me i checked before welding anything. you will have plenty of travel before anything hits
  30. 19Fordy
    19Fordy
    Based on the appearance of your welds, I'm guessing you already know the answer. Looks nice.
