Hot Rods Got another Tudor and now want to chop it
Discussion in 'The Hokey Ass Message Board' started by A Rodder, Oct 21, 2012.
  1. wagoon78
    wagoon78
    looking good. can't wait to see the body on the chassis. Still trying to figure out my chop, but plan to drive this summer and chop next winter.
  2. fordman1
    fordman1
    Very cool, do you have a target date to have it up and running this summer?
  3. A Rodder
    A Rodder
    That is for sure, but with all the littles at home, I get NOTHING done there! My employee would much rather work on the hot rods than repacking bearings and putting on trailer hitches so its a win win all the way around. He is a great help.
    That is a good plan. This chassis came out from underneath my Coupe and that was the plan, do a little to make it cool for a summer then tear into it and do it up right as time an money allowed. Heavy chops are cool, but I REALLY like th look of a two inch chop.
    Thanks, it was a complete running driving car on Monday, roadworthy and all. I want to clean everything up and ultra detail everything before the Tudor body goes on it. If I bolt the body on on Friday it will be a runner. The only things I have left are body related, as in the glass and dealing with upholstering the seats, and figuring the tailight treatment.
  4. bitchin, please tell me the steelies are staying on the coupe though.
  5. A Rodder
    A Rodder
    Absolutely.
    I am putting these tires on wires and will run them on this chassis or swap them with mitchs wire wheels and tires and run these on that car.
    Wide whites will go on the steel wheels on the coupe.
  6. A Rodder
    A Rodder
    More progress
    Here shows some of the detail on the frame right after the Coupe came off and the Tudor goes on.
    After a lot of cleanin[​IMG]
    Well Hells Bells, stupid not to pull the Banger at this point.
    Sandblast, prime, paint, repeat......
    Couldn't be more pleased
  7. KustomCars
    KustomCars
    from Minnesota
    This is awesome!!
  8. triumph 1
    triumph 1
    Looking good! Nice work.
  9. A Rodder
    A Rodder
    [​IMG]With the sun going down, we are looking really good!
    And swapped to some '35 Ford wires freshly powdercoated black wearing new '32 caps.
    LOOKS WAAAAY BETTER FOR THE TUDOR
  10. woodz
    woodz
    Lookin good Joe,
    Cant wait to see the Tudor on this frame.
  11. Joe, I'm very impressed! Your doing a bang up job and this is going to be a beautiful car!
  12. A Rodder
    A Rodder
    sneak peek.....
  13. SaWeeet! The bar has been raised....for me anyway!
    Don't be surprised if you receive a PM or two asking questions.....;)
  14. A Rodder
    A Rodder
    Turned out much better than I could have hoped for.
    Next up is dealing with wether or not to ceramic coat the header and intake or leave bare metal but coat it with gibbs.
    And the other is the tailight treatment. Either gonna do a single A light with plate mounted below off on the left or possibly centered on the back down low.
    Any thoughts? ???
  15. woodz
    woodz
    Oh man that looks killer!
    I seem to remember you lifting the rear spring mount on the rear cross member to get the height you wanted and then making a box inside the coupe to cover it, did you have to clearance the body of the tudor to clear the mods on the rear crossmember?
  16. A Rodder
    A Rodder
    I told my painter to brake out the sawzall to clearance it before I got there.
    We set the body on and it was hung up a little. Rather than trim it we went ahead and put in the body blocks. Its surprising how much they space uo the body. Once they were in there is a solid half inch clearance on the sides.
  17. What about mounting the taillight and rear license plate on a spare tire mount?
  18. general gow
    general gow
    MODERATOR
    oh my, goodness gracious...
  19. A Rodder
    A Rodder
    Mounted in that location woukd be good but the bracket itself sticks out really far because holds the wheel at its center. And..... I ebayed it lol
  20. NEWFISHER
    NEWFISHER
    from Oregon
    Center the tail light down low, keep it simple. I don't want to have to repaint anything when I own it LOL
  21. A Rodder
    A Rodder
    You wanna pop for the 32 shell and insert also?
  22. MATACONCEPTS
    MATACONCEPTS
    If your going fenderless, paint the frame the same color. It makes it look more like one complete matching car, not different peices.
    I like it. I want to hug it & rub my check against it. Paint the FRAME!!!
  23. NEWFISHER
    NEWFISHER
    from Oregon
    The Harley needs a front tire and a detail before it sells or I would :)
    I'm up for installing it for free
  24. One thing about a model a you can chop those suckers in a day. Dramatic easy mod. Well done.:)
  25. A Rodder
    A Rodder
    Thanks!
    We just put in the new motor mount kits from sac vintage ford and the gasket arrived as well so the engine parts should be going on soon.
  26. A Rodder
    A Rodder
  27. KustomCars
    KustomCars
    from Minnesota
    I like it alot.
  28. GARY?
    GARY?
    Yeh Joe, you ain't messin' around. That looks great.
  29. wagoon78
    wagoon78
    Wow, looking good.
    I have a 32 taillight center mounted down low. Sorry about the bad photo, it is all I had on my computer. I will try and get a better one.
    better photos of the bracket. Work done by Dirtyest Devil with parts he had laying around.
  30. A Rodder
    A Rodder
    I held up the A light and plate in that location and it just kind of seemed like it stuck out far. Yours looks pretty good though. Is a 32 light not as deep as an A light?
    And lastly, is your bracket mounted to the body directly behind the light, or does it drop down and connect to the bottom thick bar where the spare tire mount bolts to?
