Technical Good substitute for roof sound deadening material
Discussion in 'The Hokey Ass Message Board' started by Sporty45, Oct 19, 2018.
  1. Sporty45
    Sporty45
    I removed the old mouse house headliner from my 47 Olds and there was a thick tar paper type material somewhat attached to the roof. It was very dried out and not really attached anymore and basically just fell out when the headliner was removed. What could I use to replace it? Is something like Dynomat a good replacement for it?
  2. I used the Dynomat in the Ranch Wagon, it worked great. HRP
    chryslerfan55 and Sporty45 like this.
  3. Sporty45
    Sporty45
    I kind of figured it would make a good substitute, thanks for reinforcing that thought. ;)
    Rich S. and chryslerfan55 like this.
  4. Mike Colemire
    Mike Colemire
    I used the peel and stick, think that's what it's called. It's at Lowes in the flashing isle.
    Rich S., 51 BIRD and chryslerfan55 like this.
  5. @HRP, have you had any issue with delamination? I want to use Dynomat on my truck when the time comes but was concerned that the heat of desert would just cook it and cause it to fall off.
    Jeff
  6. Sporty45
    Sporty45
  7. Blues4U
    Blues4U
    from So Cal
  8. Sporty45
    Sporty45
  9. Slopok
    Slopok
    I try to stay outa the Flashing isle!:eek:
  10. low budget
    low budget
    from Central Ky
    Dont look Ethel!:eek:
  11. Mike Colemire
    Mike Colemire
    That's it, I was close. Think it's like $16 a roll, works great.
    low budget likes this.
  12. 52HardTop
    52HardTop
    There is also the Frost King Duct insulation. It's also in a roll with an aluminum side on a rubber material. I used it in both of my Chevys. I put it on the floors and the inside of the car side of the firewall. It is a good substitute for the highly expensive product that is made for cars. It is in The Home Depot where the heating and cooling and duct work materials are. You will find some videos of this stuff too.
  13. deathrowdave
    deathrowdave
    from NKy
    I went to Lowe’s and Home Depot , yesterday they both state we no longer care Frost King peel and stick . Any ideas of another chain store to find it ?
  14. Sporty45
    Sporty45
  15. Sporty45
    Sporty45
    Thanks everyone! :cool:
  16. BJR
    BJR
    Just wipe down the the under side of the roof with some acetone or lacquer thinner first, the sound deadener will stick much better.
    Blues4U and Sporty45 like this.
  17. TagMan
    TagMan
    Short detour......will the adhesive-backed sound deadner stick to epoxy primer permanently?
  18. Bandit Billy
    Bandit Billy
    Use the little roller they sell with the Dynomat and lean on it. It'll make the job look nicer, and it will make the adhesion better. I have never had an issue with it coming loose. Dynomat makes thin stuff for headliners, heavier stuff for floors and firewalls, and a cool vapor barrier sound deadener for the doors.
    fauj likes this.
  19. You can make your own little roller with a 4 inch roller and a piece of plastic PVC pipe.
    Sporty45 likes this.
  20. BillSchmid
    BillSchmid
    from Ohio
    The seal and peel works good for floors, but it will eventually sag and detatch itself from the roof in hot weather.
