Technical Good cam choice for mild flathead
Discussion in 'Traditional Hot Rods' started by aonemarine, Nov 14, 2013.
  1. Jimmy2car
    Jimmy2car
    from No. Cal
    Does anyone have the specs on the Potvin 3/8's? Lift? Duration, etc?
    Thanks
    Jim
  2. Ghostrider1
    Ghostrider1
    Heck than looks like a wartime John Deere "AR". Pretty rare dude.
  3. aonemarine
    aonemarine
    from Delaware
    It is a john deer, been trying to figure out how to get it out of it hiding spot but the trees are all grown up around it and its stuck fast.
  4. HotRodMicky
    HotRodMicky
    0.37 lift
    280 duration
  5. banjorear
    banjorear
    I'll pull the timing card about and post them. Will be tomorrow.
  6. Jimmy2car
    Jimmy2car
    from No. Cal
    Thanks Micky.
    Seems just the same as the 425, but with less lift.
    Thanks again. Seems like A GOOD CAM
  7. HotRodMicky
    HotRodMicky
    The 425 is a whole different world than the 3/8
    I like the 425
  8. im reading this with some interest-I have a o/g jenks 3/8 and a 425-in boxes still-have been wondering about the streetablity of the 425
  9. Villlage Idiot
    Villlage Idiot
    This is my new favorite. It's Cory Taulbert's roadster with a Winfield SU1A.
    http://www.youtube.com/watch?v=vTXMcYn6ZgE
  10. HotRodMicky
    HotRodMicky
    If you look on the lobes , you will see the 3/8 is round on the
    Top , where the 425 has the shape of a (house) roof
    The lifter need more spring preasure to follow the shape
    On the 425 and i guess lobe and lifter wear will be greater
    But its a GREAT cam , you just should check valvetrain wear
    More often.
    Dont use adjustibale lifters with the 425, too heavy
    I have 8000 miles on my 404a radius lifter cam and cant
    See or measure any wear and the 404a has a wild lobe design
    ,too
    Btw ,its the best cam i ever used in a flathead .
    Wide power range
    Just lacks the sound compared to a 425
  11. LSGUN
    LSGUN
    from TX
    I've heard the SU1A specs are all over the place with the grinders. Apparently it was used as a reference and then adjusted to the setup.
  12. Jimmy2car
    Jimmy2car
    from No. Cal
    im reading this with some interest-I have a o/g jenks 3/8 and a 425-in boxes still-have been wondering about the streetablity of the 425.
    Stroked36:
    I run the Potvin 425 in a 288" flathead.
    It has a rough idle @ 800 rpm, but will idle in gear. Of idle is instantaneous.
    I have the timing set at 12 initial, 28 max, all in by 2200 rpm. Dist is helmet type with Pertronix module. Two carbs. Engine pulls hard, sounds great.
  13. aonemarine
    aonemarine
    from Delaware
    Lots of choices thats for sure, I didnt realize there were that many manufacturers of cams for these engines.
  14. Russco
    Russco
    from Central IL
    I put one of those 1007B grinds in my 284 stroker on Petes advice and man did that thing pull hard in bottom and midrange that's a perfect cam for street driven flatty. I have a video somewhere of it running sounded great too
  15. aonemarine
    aonemarine
    from Delaware
    Break out that video, I want to hear this thing!! :D
  16. Villlage Idiot
    Villlage Idiot
    I don't know much but I understand that Mr. Winfield used the SU1A as a kind of generic designation that could apply to more than one grind. I believe that H&H built the engine in the video and it seems to have a pretty aggressive idle. I talked to one of the more reputable cam grinders about an SU1A and they advised me that they can only grind a mild version (sorry I didn't get the specs). So they knew there were more.
    Then I searched Fordbarn and found a fellow who grinds a lot of banger cams but also does flathead V8's. He grinds the hotter version of the SU1A as well as a milder Winfield grind called an SU1R. But he doesn't grind the milder SU1A. He told me that the specs of his SU1R are between the two versions of the SU1A.
  17. Villlage Idiot
    Villlage Idiot
    I remember that video. The engine sounded great with that cam but I haven't been able to find the video lately. Here's another video of a 1007B and it's another HAMBer's car
    http://www.youtube.com/watch?v=JITKQyXKgTk
  18. aonemarine
    aonemarine
    from Delaware
    That does sound pretty nice...
  19. aonemarine
    aonemarine
    from Delaware
    then again the 400 jr sounds awsome, but im not sure if I want all this....
    <iframe width="420" height="315" src="//www.youtube.com/embed/xLqH7eoZiT0" frameborder="0" allowfullscreen></iframe>
  20. thanks for the replies/info fellas
  21. Russco
    Russco
    from Central IL
  22. aonemarine
    aonemarine
    from Delaware
  23. 40FordGuy
    40FordGuy
    I like the Isky Max 1, Good street manners, in an 8BA dual 97's.
    4TTRUK
  24. Those videos are badass! Scroll down a hair on the above video for that pre-war nitro. burning car. That thing never gets old....
  25. banjorear
    banjorear
    Yeah, that thing sounds friggin' awesome.
  26. DjNeil
    DjNeil
    I'm building up a 255 Merc flatty with tri power 8:1 Edelbrock heads and it's going in a 51 Merc
    how much does the weight of the car need to be taken into account when choosing the cam. I was just going to stick an Isky 3/4 race cam in and hope for the best.
    I want the rumpity rump but don't need low down torque. It's mainly highway driven at 60mph
    Thanks
    Neil
  27. hoop98
    hoop98
    from Texas
    Here is a basically stock 255 Merc with dual carbs and header, first with the stock 8CM Merc cam, then a max 1.
    Red lines are power, green torque, lighter is ISKY, Power scale is left, torque is right
    Tweaking engine for 3 deuces and 8-1, Max 1
  28. flatheadz-forever
    flatheadz-forever
    from new jersey
    no matter what cam you pick you already made the most important decision by choosing to stick with a flathead imho id go with the 400jr or a potvin grind by pete1
  29. gotit
    gotit
    How do I post a video? I have a video of my flathead with a 400jr.
  30. DjNeil
    DjNeil
    Does the fact it's going in a 51 Mercury full bodied car make a difference due to the weight of the car compared to a light hopped up jalopy
