Technical Going to get to the bottom of this damed high RPM miss.
Discussion in 'The Hokey Ass Message Board' started by 34Larry, Apr 19, 2020.
  1. 34Larry
    34Larry
    81 years ago today at 7:05 PM in Helena , Montana a new soon to be "car guy", popped out, stood up and said, "floor it, I've arrived.
    I can't and won't complain a bit. There's been some flat cam days, out of gas days, but more petal to the metal days than can be counted. Life for the most part has been wonderful in spite of all the misses I've caused for myself. Three wonderful daughters, (one of them waiting in heaven for me), (2) loving wives, and my younger brother who
    I would have never made it with out, and I posse the strongest brotherly love for that, is possible.
    I've loved the car culture since about early 1947. My best friend and I could name every car a what year it was by then.
    So fast forward though 81 years>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>to this morning.
    Where to go now, what to do.
    Well as you guys know I have and rebuilt a former 34 (3) window Ford from the 50's and have my issues with it since finally getting on the road in .'17. Well it has run just okay, having brake, transmission problems and after the trans was replaced it developed a miss higher at RPM that has gotten some better but not gone away. Just running around locally it is normal unless getting into it in 1st from a light. It idles great, starts great but damn it, it ain't right. So yesterday I decided it will be fixed and running right or else. So right now the tare down has started, suspecting a vacuum leak because last time my helper installed an intake gasket that had been torn in half. But what ever it is, I'll find it and get this thing on the road like it should be.
    34larry, still on this side of the grass and turning wrenches...……………………...:rolleyes::D
    48fordnut, mctim64, Boryca and 10 others like this.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
  3. BoogittyShoe
    BoogittyShoe
    How 'bout a new set of plug wires? That's a lot easier than pullin' the manifold. Then, if that's not it, well, at least you'll have a new set of plug wires.
    loudbang and firstinsteele like this.
  4. Don't forget that a part isn't always good just because you "know" it is good; in other words don't assume.
    loudbang and Boneyard51 like this.
  5. big duece
    big duece
    from kansas
    A vacuum leak would give you a high idle, that is hard to settle down...
    loudbang, Baumi and Tim like this.
  6. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Why not put a vacuum gage on it that you can see while driving and take a test drive......unless you can duplicate the miss in the drive way. Then maybe try pulling plug wires one at a time and see if its one cylinder missing or random cylinders.
  7. TRENDZ
    TRENDZ
    “Since the trans was replaced”
    Check grounds around the bell housing area, and make sure the distributor wasn’t resting on the firewall when the trans was dropped. I don’t know what you have for an engine, so if none of this applies, my apologies...
  8. winduptoy
    winduptoy
    Hey Larry, Larry here....Happy Birthday you old fart!
    I always like to run the engine in the dark of night and take a good look over
    Funny what lights up from time to time
    Last time it was a spark plug that illuminated the porcelain and it ran fine at idle
    Enjoy the challenge and hope I've got your attitude at your age!
    Got to go hunt for Curly and Mo....
  9. Long shot, but you do have the coil wired correctly? They will work if wired backward, but better at low rpm and then poor at high rpms. Also agree new plulg wires can't hurt and the view at night will show any leaking. A little is OK. But a light show is bad.
    loudbang and Tim like this.
  10. Doublepumper
    Doublepumper
    Last time I chased down a high rpm miss it was a loose distributor shaft allowing the points gap to fluctuate.
    Good luck, hope you find it without too much hassle and....Happy Birthday!
  11. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    Can't help with the miss but anyone in their 80's driving a 34 is my hero. Happy Birthday!
  12. When a new problem shows up, go to the last thing you fixed.
    a bumped cap can mess things up. Wires can have a semi crappie terminal connection that works till you bump/brush up against it.
    Yep, and plug wires get old, look great hardly any use but just bad.
    loudbang and olscrounger like this.
  13. 41rodderz
    41rodderz
    from Oregon
    Happy birthday too you. :)
  14. 31 5w
    31 5w
    Happy B-Day, 68 yrs. ago today I popped out also! Been great most of time, survived brain surgery 32 yrs. ago and retired 6 yrs now. Been blessed w/ my 32+ "bonus yrs." If I make it to 70 I will have lived as many yrs. Post surgery as before.
  15. 41 GMC K-18
    41 GMC K-18
    Happy Birthday to you Larry !
    Be safe in everything that you do!
    Don't move while the room is in motion!
  16. Well; Happy Birthday!
    loudbang and 41 GMC K-18 like this.
  17. rockable
    rockable
    Remember, the engine torques to one side when you load it hard. (DS, I believe.) Could you be momentarily shorting a wire against the engine under acceleration? I had that problem once, where the wire was intermittently touching the exhaust manifold. Good luck!
  18. borderboy1971
    borderboy1971
    from Canada
    Happy bday Larry. I respect your dedication to find that miss.
  19. boutlaw
    boutlaw
    Happy Birthday Larry, Im behind you by 9 and hope Im doing what youre doing at your age. Good ideas provided so far, especially looking back at last work, but I tend to think ignition as well, seems a vacuum leak would cause different symptoms than a high RPM miss. Regardless, I have no doubt youll find the problem and post the fix. You didn't mention whether electronic or points ignition, I assume electronic, which to me is easier to troubleshoot. Points and condensers are becoming more difficult to find, especially a quality condenser. My RPM misses seem to always be rotor/cap related, even the MSD caps and rotors are not quality any more, and high energy ignition systems seem to find the flaws in each.
  20. catdad49
    catdad49
    Happy Birthday, Larry! Where are you going in such a hurry?
  21. Hardest to find problem I ever had was on a '57 Bird. Turned out to be a busted diaphragm in the distributer vacuum advance unit. Good luck and be sure to tell us what you find.
    Charlie Stephens
  22. cheepsk8
    cheepsk8
    from west ky
    Here is something worth a try. An old guy taught me to work on my cars way back when. I had a 327 that would only cut out on high rpms and on kickdown when the motor was under load. This went on for a long time but the miss never crept down into the normal driving rpms. Finally I asked him about it and he handed me a new coil wire. The boot insulation must have been compromised. Problem solved.
    tb33anda3rd and loudbang like this.
  23. Hey HAPPY BIRTHDAY!
  24. I have been chasing a miss for a long time.
    Msd distributor pick up went bad. Ohm test showed it as proof. Still missed.
    The light on the msd box was flashing. Swapped coils worked better. Still misses.
    Ran the numbers on the holley carb. This carb was brand new. Front and rear metering plates were backwards. Runs better still misses.
    After I got lit up setting the timing grabbing the dist cap I figured something was up. I changed the cap rotor and wires with new top of the line msd parts. Runs great. It is now a tire frying car.
    Sometimes it's more that one thing stacked up that makes it hard to sort out.
  25. chargin03
    chargin03
    Happy Birthday !
  26. gene-koning
    gene-koning
    Didn't you lift the body off the car to fix the transmission behind that Hemi?
    I think I would be looking towards a missed ground, or a wire with a broken or skinned insulation, or a loose wire or a bad electrical connection in the ignition primary system. Something (or anything) that could have happened when the body was reinstalled.
    I don't believe a vacuum leak will give you a high rpm miss, but strange things do happen. Gene
  27. UNCLECHET
    UNCLECHET
    Happy Birthday and I have no doubt you'll find the problem! And really that's part of the fun.
  28. Boneyard51
    Boneyard51
    I put a new set of “ good” spark plug wires on a ot car one time and it ran bad! Checked everything..... put another set of different brand wires on.... ran great! Brand new set was junk, from the very start! And that was a long time ago! Things are worse now!
    Bones
    PhilA, Desoto291Hemi and loudbang like this.
  29. Baumi
    Baumi
    I was chasing a higher rpm ( above 4k) miss for years until the coil went and the car would not start anymore. With the new coil the high rpm miss was gone ...
    Happy birthday, Larry!
  30. loudbang
    Happy birthday old rodder. :rolleyes:
    Roothawg, winduptoy and catdad49 like this.
