Projects Going hot rodding
Discussion in 'Traditional Hot Rods' started by dodgedifferent2, Jun 9, 2018.
  1. dodgedifferent2
    dodgedifferent2
    Just finished up a 1967 dart gt. So I went out and bought a 1930 ford model A coupe body.
    It has been chopped 3 inches already. The job was a crappy chop so I will have to redo that in the future.
    I have myself a 4 inch dropped I beam axle with disc brakes.
    Planning to use an overdrive a833 that I have sitting on shelf.
    Undecided on engine at this point. Thinking gen 1 hemi, flathead or nailhead. Watching the classifieds.
    Thinking of going 8 3/4 axle then I can swap pots with the dart. (Unlikely ever will but I already have a 3.55 sg)
  2. dodgedifferent2
    dodgedifferent2
    Picked up a subfloor to copy and get measurements
    Now the first decision.
    I was originally planning to copy a model A frame. Then the daydreaming started.
    Now I decided to build my own 32 ford frame from a tech thread I found here
    So I found a blueprint of a 32 ford frame. Blew the side profile up and printed it on 16 pages. Taped them together and copied on to 1/4 inch plywood I had sitting around.
  3. dodgedifferent2
    dodgedifferent2
    Now the fun begins.
    I picked up a plasma cutter cheap from the classifieds.
    Went and bought a sheet of 10 gauge steel.
    Traced my pattern and cut out the profile
    I do have do the body reveal line.
  4. dodgedifferent2
    dodgedifferent2
    Now the overhead view
    Armed with blueprints
    I started to lay everything out on the floor.
    Put cowl on a piece of plywood
    Layed the subfloor down
    Traced the cowl and subfloor lines on to the plywood and setup where the framerails will be.
    CudaChick1968, jazz1 and Jalopy Joker like this.
  5. dodgedifferent2
    dodgedifferent2
    Did not accomplish much the last few days but I did get the top profile cut out of plywood.
    I also cut out one piece from steel today
    Next week may have a bit more progress
    CudaChick1968 and Jalopy Joker like this.
  6. dodgedifferent2
    dodgedifferent2
    Making a pattern for the body reveal next up is the actual labour for that :)
  7. dodgedifferent2
    dodgedifferent2
  8. dodgedifferent2
    dodgedifferent2
    Clamped the sides all together and started grind them all so they are all exactly the same.
    Now the body reveal.
    Clamp down and beat it with a hammer.
    Don't forget a left and a right ;-) 20180604_162735.jpg 20180605_150020.jpg 20180605_151807.jpg 20180605_154443.jpg
  9. dodgedifferent2
    dodgedifferent2
    Looks like I am going nailhead.
    Picked up a 401 nailhead with a trans.
    No plans to use the slushbox.
    Looks like I may have to make my own scattersheild to mate my a833 to the nailer
  10. rydetyme
    rydetyme
    Very cool!
    I'll be watching this one!
  11. bct
    bct
    Big job but seems like you are enjoying your time. I'll be watching. All the best.
  12. King ford
    King ford
    from 08302
    I don't think you want to totally copy 1932 frame blue prints for an A body,..I think most guys alter the the Duce rails ( looking down from above) to fit the shape of the A body....I am sure you can find further information on here....good luck and enjoy!
  13. Labor of love.
  14. Is that front end Vintage Parts brand or similar?
    If so, do a search for Hoffman on here. You'll find plenty.
    Parts/brands under the Hoffman Group umbrella should not be used on real cars. But they are cheap.
    There's another thread today where this has come up.
    Use this:[​IMG] at the top of the page.
  15. dodgedifferent2
    dodgedifferent2
    It's pinched at the firewall.
    Otherwise a direct copy
    Front end was bought from a local guy No clue on brand but it does have a similar speedway logo cast into it. Just missing the s
    Yes I bought one from speedway before but sold it before I ever used it because I didn't think I would ever build a model A when I bought the dart.
    The wife has already claimed this one because i have the dart. She even has colour picked out and rims and tires :-D
    chevy57dude and jnaki like this.
  16. Like this:
  17. edcodesign
    edcodesign
    Nice job, good luck .
  18. sloppy jalopies
    sloppy jalopies
    Wescott's Auto Restyling puts out a "pinched" print for an A on '32 rails... back page of the older catalogs...
    IMO ... pinch the rear a little too, so the A wheelwells will clear the outside of the frame rails... otherwise you must trim or pry the wws to clear... no pix.
  19. dodgedifferent2
    dodgedifferent2
    Yes I had that print in front of me but the measurements were not adding up. The rails would of been wider than the cowl
  20. sloppy jalopies
    sloppy jalopies
    Also 1932 frames are made for a 106" wheelbase...
    model As are 103.5"... if you run the stock hood you must slide the rearend forward 2.5" ...
    if you run the stock '32 rear suspension the cowl will move back 2.5" requiring that the frame be pinched even more ..... HIH
    pitman likes this.
  21. dodgedifferent2
    dodgedifferent2
    Hood? Hot rods have those?
    Yes aware of the wheelbase difference. Reason it's called hot ridding. Welders torches and bfg' s make everything work :)
    CudaChick1968, Tim and cactus1 like this.
  22. chevy57dude
    chevy57dude
    Spousal support goes a long way.
  23. dodgedifferent2
    dodgedifferent2
    After a long busy period I had some free time so I started to put the puzzle together. 20180710_160853.jpg 20180710_160858.jpg 20180710_160937.jpg
  24. dodgedifferent2
    dodgedifferent2
    A bit more tinkering today.
    One side rail together. Just have to finish weld and do the other rail.
  25. seb fontana
    seb fontana
    from ct
  26. dodgedifferent2
    dodgedifferent2
    Ran out of mig wire.
    So I was disassembling the 401 nailhead.
    2 stuck pistons and one seized wrist pin.
    Lots of gummy greasy oil.
    Block will need an overbore and a complete rebuild.
  27. kursplat
    kursplat
    moving along. shouldn't be any dust settling on this project.
    Jalopy Joker likes this.
  28. Tim
    Tim
    from Raytown Mo
  29. Jalopy Joker
    Jalopy Joker
    Thanks for sharing pics, info, etc - after building 2 or 3 more it will get to be easier
  30. seb fontana
    seb fontana
    from ct
    Yeah; third one's the charm..
