Technical GM dual throttle return spring question
Discussion in 'The Hokey Ass Message Board' started by Hotrodjohn71, Mar 6, 2021.
  1. Hotrodjohn71
    Hotrodjohn71
    What is the reason for the dual throttle return springs on the 60s and 70s GM engines? Where there is a large outer spring with a smaller inner spring. Is this just a safety feature in case one of the Springs breaks?
  2. squirrel
    I think so.
    Sent from my Trimline
  3. Russco
    Russco
    from Central IL
    I assume so, 2 return springs are required for many sanctioning bodies for racing as well.
  4. I had a factory spring where one wire was folded in half, then the double strands were wound into the return spring.
    Safety inspector tried to say it was not double. It removed it so he could see the two strands up close.
    Deuces and Hotrodjohn71 like this.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Just guessing but I'll bet it had more to do with spring rate , as the springs were different shapes & wire sizes ...
    winduptoy, Deuces and Hotrodjohn71 like this.
  6. harpo1313
    harpo1313
    from wareham,ma
    Backup spring, a very good asset.
    Deuces, Hotrodjohn71 and tractorguy like this.
  7. I used to do safety inspections. It is written in our vehicle standards act. Yes for safety reasons in case one breaks. I'm sure other jurisdictions have different regulations though.
  8. poco
    poco
    from oklahoma
    I was a inspecter for nsra and dual throttle springs were mandintory.
  9. jimmy six
    jimmy six
    SCTA-BNI was the same. But some inspectors had a funny way of counting. You could have ten springs and count each one and some of them would want one more. By the way shaft springs never counted even if they were on each side....
    Tman, Deuces and Hotrodjohn71 like this.
  10. saltflats
    saltflats
    from Missouri
    Thought that was a D.O.T. thing, not sure what year it started.
  11. I too was on a NSRA safety inspection team, that's something they look for, it is a safety feature if a spring was to brake the other will keep the throttle from going past center is what I remember as the reason for the 2 springs. HRP
  12. Yep still in the book. One inspector was wearing a guy out about not having a spring one day.
    Was able to show the lead inspector how recognize a GM throttle body. Late eighties vintage.
  13. mcsfabrication
    mcsfabrication
    Cheap insurance.
    Hotrodjohn71 and Deuces like this.
  14. Deuces
    Deuces
    Holleys have a primary spring that are wound up over the throttle shafts...
    Hotrodjohn71 likes this.
  15. jimmy six
    jimmy six
    Not countable with racing organize ran with even though I’ve shown the inspectors that with all other springs removed and the throttle rod or cable attached or not, at wide open throttle held by hand, let go, the butterflies slam shut.... still a no go. 2 additional springs or go home.
