gluing rubber to metal choosing a glue
Discussion in 'The Hokey Ass Message Board' started by paulmars, May 24, 2013.
  1. paulmars
    paulmars
    gluing rubber tire to metal wheel on a cylinder or reel lawn mower
    What's is the best glue for a good lasting stick?
    tks,
    pa
  2. used to be super weatherstrip, menards may have new adhesive that will do ??
  3. 3M super weatherstrip adhesive. It's black and comes in a red tube.
  4. jazz1
    jazz1
  5. blowby
    blowby
    from Nicasio Ca
    Is there something better now than Gorilla snot?
  6. Windshield urethane
  7. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Slime that goes in your tire... just try getting a tire off a rim thats had that shit in it.
  8. oldcarguygazok
    oldcarguygazok
    from AUSTRALIA.
  9. X 2. That stuff is great!!!!!
  10. paulmars
    paulmars
    epoxy pc-7 will that work? and Lacquer Thinner to clean the contact surfaces?
  11. paulmars
    paulmars
    Im thinking of using contact cement. You can
    put the pieces together before the glue dries
    and that way get some time to move and
    situate the parts properly before they are
    'stuck' together, right?
  12. M224SPEED
    M224SPEED
    from Missouri
    I agree with the guys on 3 M super weatherstrip,comes in black and also yellow,just follow the directions,I have been using this stuff for over 40 years !!
  13. We call the yellow version "Yellow Death" because if you get it on you it's there 'til the day you die. :D :eek:
  14. Studebricker
    Studebricker
    from TX
    I actually just recently used Loctite to glue a rubber strip to metal trim and it worked great.
  15. paulmars
    paulmars
    here is what its used for. I thought I posted this. I also have pics.
    From the lady I fix this for:
    I bash that mower around the yard like nobody’s business. Talk about self-propelled, sometimes I push it as hard as I can under the grapefruit tree so it comes out the other side cutting. I run over whatever is in my way. I run it backwards and forwards. I run it along the grass at the edge of the sidewalk. The grass slopes there, so I have to mow it at an angle, with one wheel on the concrete. When I mow, I zoom. I want to get it done as fast as possible. It’s how I roll.
    I will add that her yard is very big.
  16. sdluck
    sdluck
  17. mashed
    mashed
    from 4077th
    I have to admit, I'm kinda turned on.
  18. ^^ that cracked me up ^^
  19. H.G. Wells
    H.G. Wells
    No, there is not.
  20. paulmars
    paulmars
    last time I checked, that snot came in many flavors.
  21. captainflight
    captainflight
    The 3M black weather strip adhesive is great stuff!
  22. paulmars
    paulmars
    better pics:
  23. Jalopy Joker
    Jalopy Joker
    Permatex Black Weatherstrip Adhesive works better for me than 3M stuff. but, for this application will take a super strength product to hold things together.
  24. I went to the 4077th for a hearing test at Camp Red Cloud .... could you repeat that?
    OP whatever your local glass shop uses ... that's the stuff you want.
  25. paulmars
    paulmars
    im thinking of drilling holes in the metal wheel around the perimeter and wrapping wire thru the holes and around the plastic wheel, once its glued in place.
  26. drptop70ss
    drptop70ss
    from NY
    super strength chunky style gorilla snot
    There is a lot if dust on that wheel, looks like 10 years high, you should wash it first.
  27. pumpman
    pumpman
    Was this thing built before 1965?
  28. paulmars
    paulmars
    1940s-1950s
    * * * 123.8172
    YARD-MAN, INC. JACKSON, MICH
    Order Repair Parts from Sears Roebuck and Co. Mention Model Number
