The thread title says it all. Does anyone have one? I'm trying to identify some GK cams, and it's one of the few catalogs that I don't have.
Good deal. Two of the cam numbers are F5M 284R and C1C 431B. These numbers are stamped on the rear of the camshafts, and the F5M cam also has RYB 21 stamped on it. The "F" cam looks like it fits small block Ford V8s, and the "C" cam is definitely a small block Chevy. Thanks for any information you may be able to provide.
What i show is C1C-431D NHRA STOCK CLASS GM NO 3733431 1960 - 1966 . SOLID. THEY ALSO SHOW CIC-431- E - F - G AS HYD LIFTER GM 3732798. The ford cam Boss 302---351 solid lifter 1.72 rocker ratio valve lash .028 closest i have F5M288-B STREET CAM.
Found more 5-1-75 G-K red line series camshaft F5M-284-R DUR 284 Lift .512 IN-EX L-C 113 VALVE LASH .025 SOLID STREET CAM good low end power 351 Cleveland.
Well, that straightens me out on the Ford cam. I'll have a few more numbers for you in the next day or two, when I get a chance to dig the cams out of the pile in my garage. Thanks!
Okay, cam number update---I screwed up on the suffix letter for the sbc cam. Really, it's C1C 431 G, not B. Also, I've got an A6M 282 R that also has 1213 stamped above the other number, and it looks like it might fit small block mopar V8s.
FOUND G-K mopar 273-318-340-360 A6M-282-R. DUR-282 LIFT- IN-- .435 -- EX--.441 L-C 110 -- VALVE LASH IN .018---- EX---.030 SOLID LIFTER STREET USE.
