Im in the inspiration and planning stages of a build. I currently have a should runSBC and Im rebuilding an A833 4speed from a 65 Barracuda I would like to mate the engine and trans either with a bell to engine adapter or preferably a trans to bell adapter. Clutch linkage is not an issue, ill be doing a hydraulic master/slave setup. If anyone has done this adaptation, let me know. Id really like to make this work Thank you as always to all you HAMBERS
If I remember right there used to be a steel scattershield bellhousing that would mate the two, but required cutting the long input of the 833 down to Chevy length. Can't remember who made them.
www.hemmings.com/stories/article/chryslers-a-833-np-440-four-speed-transmission www.classicjunkyard.com/new_process_a833.htm
Chevy used the NP833/NP440 from 1981-87 in certain pickups with two different bell housings- one has the Mopar style bolt pattern like the A833. They are hard to find, but not impossible. I'm actually looking for the linkage and shifter/mount for my NP833
Actually found an adapter here https://transmissionadapters.com/co...tes-1/products/mt1001801-a833-to-chevy-manual
At one time the A833 was a popular upgrade for a lot of racers . Very strong transmission ,,,iron case and strong gears . Tommy
