I am building a '29 Ford closed cab pickup and looking for some input on gear selection since I still need a third member! The truck will probably weigh maybe 1800#. Powered by a SBC 383, mild cam, Edelbrock 600 cfm. Built 700R4 w/Transgo kit, Covette servo, Z-pack. 1800 - 2000 stall converter w/lockup in overdrive. 30 inch MT tires. The rear end housing is a narrowed 8" Ford. Available gearing is: 3:55, 3:80 & 4:11. I am leaning toward a 4:11 posi. Too tall a gear?-----What do you think?
With 30" tires and an OD trans I think the 4:11's will be a good choice. Should give you 70MPH at a little over 2200 RPM.
4.11 s will put you at 2000-2100 rpms in od at 65 MPH. Sound like that will work well with your set up. Posi too!
