The gauges in my 62 unibody have gone bad. I tested them yesterday. I would like to go from the 6 volt sluster system to a 12 volt. Are there gauges that are compatible with my cluster?
Sorry, yes this is a 12 volt system, but aren't the temp and gas gauges 6 volt and a cluster voltage stabilizer is used to reduce the voltage? Thanks 302aod for the input. The original gauges are much more expensive that I had hoped and thought I could replace the old gauges for upgrades in the same cluster location. bob
I tested gauges with two d cell batteries in series. Put them together and checked with a meter. Had power, but no movement in gauges. The voltage stabilizer is shot. It actually smoked. Thinking it took out gauges because they worked, sort of, until that point.
