I'm looking for someone who makes rebuilt original style gauges for an AD pickup. The problem I've run into is finding a place that converts the fuel gauge to 0-90 ohm. Any suggestions?
if you do a search there is a really good article on switching the AD gauge face onto a modern gauge. slick,easy and cheap.
Another option is Opel GT gauges. They fit with just some tabs welded on to bolt them in. Gives you a tach and 150 mph speedometer. Then I mount oil,gas and temp under the dash. Clark
I ran into the same problem. I could not find anyone who could change the 0-30 ohm gauge to a 0-90. I installed new gauges inside the old buckets instead. Dolphin seemed to be the only aftermarket gauge supplier that had 0-90 ohm capabilities. Check out this link for my original post on this. http://www.jalopyjournal.com/forum/showthread.php?t=265599&highlight=gauges
