Technical Gasser steering linkage questions.
Discussion in 'Traditional Hot Rods' started by TooManyFords, Oct 13, 2014.
  1. TooManyFords
    TooManyFords
    from Peotone IL
    Just bought a 60 Falcon that was some one else s Gasser project. They had extended the pitman arm about a foot and was running a stock f100 cast front axle. I removed that and have a tube axle with Econoline ends. Drivers side only has the one mount as does the passenger side. I have spent the last 3 hours searching here and other places looking for a good picture of linkage . Does anyone have clear pitchers of what they are using .
  2. FlynBrian
    FlynBrian
  3. TooManyFords
    TooManyFords
    from Peotone IL
    No problems with the drag link hitting the right spring?
  4. FlynBrian
    FlynBrian
    Shouldn't be a problem your draglink will be connecting 2 & 3/4 inches in from where the tierod attaches to the steering arm and rotated vertical. Shouldn't even come anywhere close to the spring.
  5. TooManyFords
    TooManyFords
    from Peotone IL
    Ok I got these random tie rods with the axle. I think that will work if I flip the axle. I havent had a chance to put wheels on it yet. Think it is too high this way any how,
    last picture is center of dust cap with unloaded springs. You can see this way it its the spring way before it will make it up to stock pittman arm.
  6. TooManyFords
    TooManyFords
    from Peotone IL
    Has anyone used an early Bronco drop pitman arm on a straight axle build?
  7. TooManyFords
    TooManyFords
    from Peotone IL
    It had a drop axle in when I got it. Guess I raise the axle above the springs.
