Hey everyone, I have a 32 Ford 3 window and I'm changing motors ( 327 chev. ) and want to put a mechanical gas pedal and linkage to the carb ( Edelbrock 4 barrel ) It now has the wire cable type and I don't like the looks or feel of it. Just wondering what others have used in this kind of setup . Pictures would be nice if you can. Thanks to everyone in advance !!!
Don’t know on a 32 with a flat firewall but you some room for the arm like 55-57 Chev unless your going to have the upper arm behind the firewall. Then you need a moving seal for the rod. Look to what’s available for circle track race cars. Cables are not allowed.
I used the aftermarket spoon type gas pedal on my '32 sedan but I cut a slot in the fire wall and the upper arm is on the engine side of the firewall, that's where the cable hooks up to the carburetor. HRP
I used he factory setup but modded it like was done in this thread...works great. https://www.jalopyjournal.com/forum/threads/tech-week-ford-spoon-throttle-pedal-update.1070843/
