gas gauge
Discussion in 'The Hokey Ass Message Board' started by 61 chevy, Aug 5, 2013.
  1. 61 chevy
    61 chevy
    my 61 chevy gas gauge says full , when I know its not, just stared doing that, whats going on? :confused:
  2. Grounding issue
  3. fordor41
    fordor41
    Or stuck float. Disconnect wire from gauge or tank and see if it goes to empty.
    If not I'd check the gauge. If it goes to empty then move to sender and ground.
  4. 325w
    325w
    If its showing full with the key on it may a bad sender. Take the sender wire lose. If the gauge shows empty it's the sender. Are the wire could have been pinched and is going to ground.
