Galaxie front clip in f100
Discussion in 'The Hokey Ass Message Board' started by few loose bolts, Feb 25, 2013.
  1. few loose bolts
    few loose bolts
    from US
    I've got a 66 F100 with a 352 FE in it. I want to lower it an improve ride quality and I've decided i want to clip it. This however has proved a challenge since I want to retain the FE which has a front sump oil pan. I'm curious if anyone has done or even considered putting a Galaxie front clip on an effie. My thinking is that I would get the independent suspension and a cross member made for an FE. Thoughts or input?
    Thanks.
  2. RJC
    RJC
    from hope bc
    We have put the latter big Ford front frame sections ontoo a couple of the 60-70 F type trucks. The big problem is there width
  3. Last edited: Feb 25, 2013
  4. few loose bolts
    few loose bolts
    from US
    i'm very familiar with the crown vic swap. i'd prefer not to do it cause the track width is too wide, especially since i'm going for a little tire tuck. plus i've yet to see one done with an FE motor, all the swaps i've seen had an engine swap
  5. JakeDW
    JakeDW
    from Missouri
    MMII or have you been talked out of it.
    Jake
  6. few loose bolts
    few loose bolts
    from US
    it's more just that i can't afford a MMII
  7. few loose bolts
    few loose bolts
    from US
    one of the best swaps i've seen is the xj6, but again, i've never seen it done with an FE and as far as i know, i wouldn't have clearance
  8. JakeDW
    JakeDW
    from Missouri
    I see then the next sale to you will be the EP Dakota kit buy some of the guys but that will most likely cost just as much.
    There is a guy running a 79 firebird front clip on a 66 with a build thread on here. It seamed to be a fine track with looks like it slid rite in to the frame.
    Jake
  9. hippy killer
    hippy killer
    you can get rear sump pan for FE
  10. JakeDW
    JakeDW
    from Missouri
    A pic of his firebird clip.
    Jake
  11. Stevie Nash
    Stevie Nash
    That's what I was thinking... :cool:
  12. few loose bolts
    few loose bolts
    from US
    i actually just came across one on craigslist, waiting for a response
  13. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    late model CV isnt that bad, but you cant run a front sump with it unless you want the motor to sit really high. i dont know much about galaxie, but id measure it up plenty, doing it just because you have it, or because its front sump friendly might bite you in the ass.
  14. Heo2
    Heo2
    65 and newer galaxie i think is doable if its
    not to wide never had a 60s f100 so i dont
    know how wide they are
    the 65 -up frontend is what they use in nascar
    today
    ps i got a 66 chassie under a 54 chevy pick up
  15. Drive Em
    Drive Em
    The '66 F-100 front end should ride nice with the correct springs and shocks.
  16. hippy killer
    hippy killer
    yeah the twin I beam is a pretty good ride
    you could also get a front end out of mid 80 F150 twd the are uper lower A arm i think
