galaxie 500 transmission swap
Discussion in 'The Hokey Ass Message Board' started by jester5388, Aug 13, 2012.
  1. jester5388
    jester5388
    i have a 1962 ford galaxie 500 with a 352 and a cruise-o-matic. i am swapping over to the C6 for the FE motors... i have it at the trans shop right now... however i do not know what flex plate and torque converter i need...should i switch to the more modern 184 tooth flexplate and get a new starter and get the torque converter that matches that?
    another thing to keep in consideration is that in the next year i will be building the 390 that is in the garage and swapping that in place of the 352(its just money thats keeping me from doing that now) i need an expert lol
  2. I would go with the later setup. Its hard to find one of those old starters if it goes out.
  3. 62rebel
    62rebel
    get the flexplate and starter for a 66-70 fullsize Ford FE. ditch the tractor starter unless you're finicky about "authenticity".
    Sage Youngblutt likes this.
  4. mammyjammer
    mammyjammer
    from Area 51
    Late flex plate and starter will cost much less than a tractor starter alone. As stated later starters are readily available.
  5. Fordguy78
    Fordguy78
    Those early starters are a real bear to change too.
