I just installed some lakes pipes on my 51 chevy that are capped but I can open when I want to. I have read several threads about drilling a small hole in the pipe to allow the condensation to drain out. I've have not run these very long but I have found puddles of water leaking out of the caps but it was only after running the engine a short time so the pipes might not have had time to get heated enough to get rid of the condensation. Any suggestions and tips are welcomed. Bill
It is a good idea on capped lakes Pipes that are hooked up to put a drain hole in them. Condensation will continually accumulate.
