I might need to be more clear about that. On the east side of Houston there is a radiator shop that I know will hot tank and am sure repair your gas tank. They speak very little english but I am sure they can get the job done. If you are heading south on 610 and exit McCarty they are on your right side before you get to the light.
thnx for the heads up. used to be easy to find radiator shops...ha. I'll see if i can find the place.....assuming you used to live in TX and or have used these guys? thnx again, Ed
A good quick repair is a Putty called "QuickSteel" by "Blue Magic" and is found at Marinas, Checkers, Autozone... it's used to seal fuel tanks with fuel in them from leaking! Mostly used where the tanks cannot be removed without destroying the vessel and where metal repairs wouldn't be feasible!
I used to live in Corpus Christi and worked in Houston until July last year. I had some work done at that shop maybe 5 years ago and saw them working on gas tanks also. The rising insurance rates and property taxes made me move. I really do miss the third coast though. I don't miss my tools rusting.
