Technical Fuel pressure
Discussion in 'The Hokey Ass Message Board' started by GARY T., Sep 18, 2019.
  1. GARY T.
    GARY T.
    from S.W. Pa
    Running 4 stromberg 97’s not progressive fuel pressure set at 2.5 when running multiple carbs all at same time should I increase pressure or leave it at 2.5. Also should pressure gauge drop to zero shortly after shutting engine down
  2. Mike VV
    Mike VV
    from SoCal
    Sounds close.
    I'd leave it at 2-1/2 lbs, take to a long, mild uphill drive, push it a bit, see if the carburetors run out of fuel. If it runs good, leave it. If it runs out, go up in pressure by 1/4lb.
    And of course, no pressure in the system, the gauge needle drops to "0" pretty quickly.
    Mike
    flatford39 likes this.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    Pressure is not nearly as important as volume , are the carbs starving at 2.5, if not , leave it alone ....
