Fuel Pressure Gauge
Discussion in 'The Hokey Ass Message Board' started by hyperfe, Jul 19, 2010.
  1. hyperfe
    hyperfe
    Anybody know who might produce a fuel pressure gauge with a lower limit? I have a 15 psi gauge with my 97's, running 2.5 pressure and can't get the gauge to to move off zero. I tried a couple different models with the same result. I'm thinking a 0-5 psi gauge might do it. Thanks, Jim M
  2. Mike51Merc
    Mike51Merc
    I have a Moon gauge that works fine.
  3. gasserjohn
    gasserjohn
    if you have a air bubble gage will not read accuratly
    bleed out the air ???
  4. scootermcrad
    scootermcrad
    So, did you ever find a fuel pressure gauge with a lower range? I'm looking for something as well.
    BTTT
  5. dickster27
    dickster27
    from Texas
    I get all my pressure gauges from Marshall, in my opinion the best in the industry and they start at 0-15, nothing lower. A good gauge would read accurately maybe your pressure is to low to register, eh?
  6. scootermcrad
    scootermcrad
    Last I fired the motor up it was right at 2.0 or 2.25 psi, or so. I've never seen a 0-5 and the only 0-10 gauges I've seen are BIG money. But for myself, personally, I can live with the 0-15 as long as everything is working right, but was thinking a 0-5 would make more sense, since it will never be out of that range, if one existed. Guessing not...
  7. crb
    crb
    from socal
    Try calling Vintage Carburetion in Montana 406-857-2137.
  8. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    A lot of low pressure stuff is measured in inches of water. Maybe see what's available in an in/h2o gauge? Used on natural gas, ....
  9. You likely will need to look for industrial gauges instead of ones directed towards the automotive market. Might have to remote mount it in a hidden place if you don't like the look, but you shouldn't have much trouble finding a 0-3psi or 0-5psi gauge.
  10. Joe King
    Joe King
    why do I need a fuel pressure gauge
  11. johnreb23
    johnreb23
    old chevy and dodge (and probably other) oil pressure gauges were 1-5 psi for a period of time, but they are generally expensive online. you could look for these at flea markets.
    a company called "national" also made very nice looking 1-5 psi fuel pressure gauges back in the 20s(?), also expensive.
    modern low pressure gauges do exist, but make sure they are rated for gasoline before you buy one.
    farmalldan likes this.
  12. GARY T.
    GARY T.
    from S.W. Pa
    Someone told me that oil-filled ones don't work well at low pressures they said drill a small hole and let the fluid out and they will work fine. Don't know for sure ,but someone told me one time???:confused:
  13. Andamo
    Andamo
    Go on line and look in the Grainger catalog. They have inexpensive low pressure gauges. Using a liquid filled gauge will dampen the needles action and the gauge will last longer. But in the cold weather the glycerin becomes stiff and the actual pressure won't be accurate until the gauge warms up. The alternative is to use a snubber in the line to a regular gauge. The snubber has a sintered metal disc inside the and dampens the action. Grainger should have them also.
    By the way, it takes 27.1 inches of water to equal 1 pound of pressure.
  14. flathead A
    flathead A
    from michigan
    I found an old fuel pressure gauge at a swap meet last week stewart warner 1 to 10 lb,
    the number on the side is 2319F1,haven't checked it out yet.4 bucks I figured I couldn't go wrong.
  15. tpahemi
    tpahemi
    I run a holly blue pump from the tank to a holly 4.5-9 psi reg. set @ 5psi. mounted on the frame in the same area where the stock sbc mechanical pump should be, from tha reg up to a low pressure holly reg set @ 2.5 psi, from it about 6" to a 6 outlet fuel block, 6 fuellines from it to the 6 97s.
  16. Blue One
    Blue One
    from Alberta
    Okay, I know this is an old thread but I also would like to have a 0-5 psi fuel pressure gauge.
    Given what you posted here at the time Dick, what’s the story on this picture that has popped up recently in another thread?
  17. 19Fordy
    19Fordy
    I emptied the glycerin out of mu gauge and now it works.
    You might also try replacing the glycerin with DOT 4 brake fluid or Dot 5.
  18. dickster27
    dickster27
    from Texas
    That is easy peasy, my friend. Just message me and I will give you my PayPal addy and we will get this thing going.
  19. Blue One
    Blue One
    from Alberta
    I’ll do that Dick. So I take it you’re still selling the 0-5 gauge like in the picture but it’s not on your website.
    I’ll send you a message, I’ll order a coil cover too.
    Thanks, Larry
  20. Blue One
    Blue One
    from Alberta
    Sent you a reply to your email with a couple of other items, if you can figure shipping and send me a PayPal invoice that will be great.
    Thanks Dick
    Top notch service as usual :cool:
    Larry
    Blues4U likes this.
  21. Joe H
    Joe H
  22. Blue One
    Blue One
    from Alberta
    Got my order in with Dick for that neat 0-5 psi gauge and one of his coil covers too.
    Thanks again Dick :cool:
  23. dickster27
    dickster27
    from Texas
    Always a pleasure Larry.
