Technical Fuel out of Accel. pump hole? Stromberg 81
Discussion in 'Traditional Hot Rods' started by FlyinA, Feb 1, 2020.
  1. FlyinA
    FlyinA
    I’m running dual original 81s on my Model A. After running for a minute fuel will suddenly start coming out of the accelerator pump hole! The inlet valve seems good and i dry set the float level, what might cause this?
  2. alchemy
    alchemy
    What's your fuel pressure?
    stillrunners and dana barlow like this.
  3. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Like Alchemy ask? More then 3 PSI can over come float,add to that if motor vibs are high{out of balance a little} it can bounce float too
    stillrunners likes this.
  4. Do you have the felt washer at the top of the accelerator pump rod ?
  5. Larry W
    Larry W
    from kansas
    FlyinA likes this.
  6. Jet96
    Jet96
    from WY
    ^^^Yup been down this road, I messed with the 97's on my roadster a lot. Couldn't get them to quit randomly overflowing. Installed a holley regulator and enjoyed a whole summer of leak-free motoring. I'm assuming you're not gravity fed from the cowl tank...
    FlyinA and winduptoy like this.
  7. FlyinA
    FlyinA
    Thanks all for the replies! I'm running a Holley low-pressure regulator right now, its supposed to be set at 2.5psi out of the box but I'm not gonna trust a piece of paper so I ordered a pressure gauge today to see if I can eliminate the issue
