Hot Rods Fuel line through frame rail
Discussion in 'The Hokey Ass Message Board' started by marfen, Nov 24, 2017.
  1. marfen
    marfen
    from sask
    ON this 32 ford I'm finishing the owner routed braided line thru the boxed front frame rail as the rh exhaust pipe is 1" away from rail...too close to run a steel fuel line past. I don't like the braided line idea and probably can make a steel gas line and get it inside the frame rail. To protect the steel line inside what do you folks recommend , heater hose, some kind of shield? couldn't find a thread on it.
  2. RmK57
    RmK57
    I used that spiral plastic hydraulic hose wrap. It would never wear through in my or your lifetime.
    mad mikey, H380 and loudbang like this.
  3. 26hotrod
    26hotrod
    from landis n c
    The hose wrap is a good idea. I have it all over my hotrod where needed and it is used on commercial vehicles as well. Just remember you don't want anything rubbing on anything..........
    mad mikey and loudbang like this.
  4. marfen
    marfen
    from sask
    thought about that spiral wrap. thx for the suggestion. It will be easier to use.
  5. I used neoprene fuel split the entire length and tie wraps to keep the metal line from rubbing against any metal on the inside of the frame. HRP
    mad mikey, wackdaddy and fourspd2quad like this.
  6. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    I did this to run lines through the crossmember, but the idea can be modified for inside a frame rail. Weld tabs on the inside the rail with the hole id for a grommet bore. Supports and isolates at the same time.
  7. Shove a 1/2" ID rubber hose ove a 3/8 corrosion proof metal line.
    mad mikey, loudbang and Texas Webb like this.
  8. marfen
    marfen
    from sask
    thank you all
  9. oj
    oj
    Is it stainless steel braid -AN hose thru the framerail? Leave it, it is in a stainless steel casing. Can't get much better than that.
  10. Roger O'Dell
    Roger O'Dell
    I think you may be able to find a bulkhead fitting. I see them advertised up to 3 1/2”,
    31Vicky with a hemi likes this.
  11. BJR
    BJR
    What's wrong with good old rubber grommets?
  12. He's not going thru a thickness of metal,
    He's Running up a boxed frame, if you will within a tube, without access to mount the line.
