What fuel line with which inner dia do You guys use for Your Flathead 2 Carb Setup? I have a german block, Eddie Meyer fuel divider valve and an electric fuel pump with pressure regulator. Thanks!
I use 5/16 inch. Make sure it runs uphill all the way to the carbs. (I have replaced the cheapie regulator in the pic with a Holley) .
My Studebaker came with 1/4" lines with no problems on a mechanical pump but I have since changed to 5/16"
You don't say which carbs you are using, but usually keep the pressure low-2 1/2 lbs. You may want to put an in line presure gauge on your car to monitor pressure. Regulators don't always work the way you may like. Good luck! Bob
When You guys use an electrical pump, do You have a line back from the carbs in gas tank, where the fuel goes when the floater in the carb is closed?
