Fuel gauge stuck on full
Discussion in 'The Hokey Ass Message Board' started by thebronc4019, Sep 7, 2009.
  1. thebronc4019
    thebronc4019
    from New Jersey
    Is there an easy way to determine if it is the sender or the gauge? Fuel gauge is stuck on full. Stays there even when power is cut off. I know it is wired properly because I have been running the car for 7 years and gauge always worked fine. I used a multi meter to run some voltage and ohm tests but can't seem to isolate the problem. My electrical diagnostic skills are lacking.
  2. BISHOP
    BISHOP
    If the gauge is stuck on full, even when there is no power to it, then that would tell me that the gauge is bad.
  3. who made this gauge?
  4. R Pope
    R Pope
    GM style gauges go to full if there's any break in the connection. First, most common thing that causes it is the fuel tank not grounded properly.
  5. 53sled
    53sled
    from KCMO
    Mine started going to full as it emptied, when full goes to half. Ohmeter says the sender is fine, so new gauge it is, again. Aren't any made in the USA????
  6. thebronc4019
    thebronc4019
    from New Jersey
    This is a GM factory gauge
  7. 51chevcoupe
    51chevcoupe
    Look at the bright side, you don't need to buy gas if the tank is full:D
    Ed
  8. SaltCityCustoms
    SaltCityCustoms
    Maybe your mileage is just better than you thought!:)
