I'm thinking of hooking up a return line on my '56 Chevy to help with vapor lock/hot start issues before the Texas summer hits hard (it's running a mechanical fuel pump). I'm going to try a 1/2" phenolic spacer first and insulate/reroute the fuel lines to see how that works -- the carb/fuel line is getting too hot after a long run and the fuel line can be routed better. It's a problem that's already rearing its ugly head. I searched this board and the Wix 33041 filter was recommended. I need it to have an orifice. Apparently Wix 33041 is unobtanium from every supplier I've found -- bummer as I prefer Wix products. Is there another part # someone can provide that functions the same as the Wix 33041? I'd like to tackle this problem soon.
I appreciate that, but I'm looking for one that accepts 3/8" line w/ the orifice. I think that one's 5/16" on the inlet/outlet.
Napa Gold 3041 Other numbers that should cross WIX Replacement for AC DELCO GF98 ATLAS FF12 BALDWIN BF887 BIG A FILTER 95041 CARQUEST 86041 CARTER GF18 DELUXE 73012 FLEETGUARD FF243 FRAM G18 GENERAL MOTORS 5650829 GENERAL MOTORS 5651119 HASTINGS FILTERS GF20 LEE LG1118 MOTORCRAFT FG12 NAPA GOLD 3041 PUROLATOR GF1118 WIX 33041 WIX OLD NUMBER WF41
F1ford.. you don’t saw what style intake you have or it’s material. If it has a carb heat crossover you can restrict it also. If not a 3/8” phenolic carb spacer really helps or has for me with every engine I run..
