Technical fuel delivery for hopped up 283
Discussion in 'Traditional Hot Rods' started by Stefan Charles, Dec 17, 2016.
  1. Stefan Charles
    Stefan Charles
    hey all, i am in need of suggestions for carburetors on a 59 283, here are the specs on the motor..
    59 block, punched out 60 over
    power pack heads 60cc 1.72/1.5 running aproximately 9.5-1 compression
    comp cams 262XE 0.462 in/0.469 ex
    msd streetfire distributor
    I am looking at a holley 570/600.. do you think that's too much CFM for a relatively mild street motor? the forums I read say to stick to 500 cfm for a 283. thanks for lookin!
  2. onetrickpony
    onetrickpony
    from Texas
    A Holley 600 with vacuum secondaries will be just fine. They are very forgiving.
  3. c-10 simplex
    c-10 simplex
    How high do you plan on revving it?
  4. Gman0046
    Gman0046
    I'm running a Holley Street Avenger 670 CFM with vacuum secondaries on a .060 327 with a Comp Cam 262H that runs real strong.
    Gary
  5. Fogger
    Fogger
    I have two cars with '57 283 engines. My roadster runs a WCFB Carter with about 400 cfm. My '55 Chevy has a 500 cfm Edlebrock. Both engines are recent builds and run very well with the small four barrel carburetors.
  6. Schwanke Engines
    Schwanke Engines
    Buy a 1605 Edelbrock, bolt it on and enjoy your car running right.
    Sent from my XT1585 using The H.A.M.B. mobile app
  7. Dooley
    Dooley
    from Buffalo NY
    I've read that the 670 is really a 600 tested or flowed differently to get the bigger number,,,not sure if true or wives tale
    Either way that or the 600 VS would be good, although the Holley 3310 780 came with the 302 sbc I beleive
  8. bowie
    bowie
    My choice would be a mechanical secondary double pump 600 cfm Holley.
    Fordors likes this.
  9. brigrat
    brigrat
    from Wa.St.
    What trans, what rear gears?
