Technical FRUSTRATED AND MAD!!!!
Discussion in 'The Hokey Ass Message Board' started by kscarguy, Jul 14, 2014.
  1. OLDSMAN
    OLDSMAN
    If you don't have baffles in the valve covers you can suck up oil through the PCV valve and burn it
  2. vtmopar
    vtmopar
    from Vermont
    So how's it running now?
  3. models916
    models916
    Rule for rubber end gaskets or bead of sealer is this: Lay the intake on the head block surface without a gasket. If it lays flat all around, use the supplied rubber seals. If it is tight on the block surface and raised on the heads you will need to use the sealer or mill the bottom of the intake. In this condition, the rubber gaskets will be squeezed out by the incorrect fit.
  4. JC Sparks
    JC Sparks
    from Ohio
    You say "it blows oil out of the engine going down the road" I take it you mean out of the seals and or gaskets. I'd warm it up and do a leakdown on it. JC
