33 pickup front spring lower plate. Is this the correct one? Spring measures 1-3/4 wide but the plate has tangs that are 2-1/4 wide. Will this create movement or allow spring to slide back and forth?
The u bolts go around crossmember also, so there is no way they have a 1 3/4" span cross is atleast .125 material plus maybe .125 clearance on each side so the span is probably 2 1/4" or little more
Thanks! My plate is definitely wrong it's measuring 3 3/8 center to center. Guess I'll be ordering up a new plate.
